Brake Ferrule stuck...
Results 1 to 4 of 4
    Dec 2008
    It appears that my sweat may have welded the ferrule on my APEX front brake. Any tricks to get this thing loose? I've tried WD-40 and PB Blaster... no luck.
    TIA
    'brifter' is a lame word.
    Carefully twist and pull w/ some good pliers. If that doesn't get it, you might have to get a new barrel adjuster. Sometimes you can drill them out if you have a the right size bit, but it almost always leaves some of the ferrule behind.
    Todays lesson: Wash your bike more often.
    I work for some bike racers
    and a bunch of skateboards
    Jun 2014
    Usually it all comes apart... twisting and pulling is the best bet.
    Otherwise, remove cable.
    I would think the cable housing would somewhat unscrew as it is generally made of a spiral steel.
    Then you're left with just the ferrule stuck in. It should come out with some pliers, perhaps using a hammer and screwdriver to collapse it inwards before pulling with needle nose pliers.
    Done
    Mar 2002
    Clip the cable, unscrew the adjuster, carefully remove the rubber grommet doo dad, and soak it in a little cup of ammonia. Ammonia dissolves aluminum oxide. Ditto Drano sink clearer. Should work fairly quickly.
    Caution: it may eat the aluminum adjuster too but, hey, it's already toast.
    Caution No. 2: Don't be tempted to do this on the bike. Ammonia doesn't play nice with aluminum.
    Caution No. 3: I would clip the cable and try to get it out with a pair of needle nose or linesman pliers first.
    It's Been Fun...See You Down The Road.
  1. Ferrule (End cap) stuck in Cable stop.
    By norman.j.singh in forum Components, Wrenching
    Last Post: 12-08-2013, 10:06 PM
  2. Need for cable cap/ferrule on brake cable?
    By DaveG in forum Components, Wrenching
    Last Post: 09-27-2012, 12:59 PM
  3. Brake cable stuck
    By FlyingYeti in forum Components, Wrenching
    Last Post: 05-31-2009, 04:45 PM
  4. rusted stuck brake cable ferrule
    Last Post: 06-04-2007, 05:54 PM
  5. stuck brake pads
    By tmac13 in forum Components, Wrenching
    Last Post: 05-22-2006, 07:21 PM
