Brake levers for flat bars that work with caliper brakes?
Results 1 to 10 of 10
    Beetpull DeLite
    My roommate just picked up an old Schwinn road bike recently, so I'm in the process of making it rideable. He's not a fan of road bike drop bars, so I traded him one of my flat bars for the old SR's on the Schwinn.
    Now, I'm wondering what brake levers to use. The drop bar levers obviously won't work, so I need some mountain levers...should I look for ones that work with cantis, or v-brakes? Tektro makes some inexpensive levers that work with both of those, should they work ok?
    Any help would be great, thanks!
    Brian
    blame me for missed rides
    Reputation: weather's Avatar
    canti levers.
    Every little counts...
    Reputation: Spunout's Avatar
    Aug 2002
    New Campagnolo flat bar levers. Very, very cool.
    https://campyonly.com/images/rumors/...t_controls.jpg
    Jan 2002
    Quote Originally Posted by GirchyGirchy
    If Tektro offers a lever that can be configured to work with either, then yes. But V-brake levers won't work.
    Shimano Levers at Loose Screws: http://www.loosescrews.com/index.cgi?d=single&c=Brake&sc=Levers%20Complete&tc=&item_id=LS-5584RB&id=84203282319
    Dia-Compe levers at Rivendell: http://rivendellbicycles.com/webalog/brakes/15112.html
    Look at inline "cross" levers too. Don't see why they couldn't be run as stand-alone canti levers.
    NeoRetroGrouch
    Reputation: TurboTurtle's Avatar
    You say "V-brake levers won't work." Have you ever tried it? I've never been able to find someone who has. I think they would.
    Canti (short cable pull) lever won't work on V-brakes because you run out of pull before you get the pads to the brakes.
    With V-levers on cantis (or road brakes), you would simply have less power, but I think it would still be way more power with the leverage you have on a flat bar than you have from the hoods on a road bike. I think the canti (or road, again) would work as good as they ever do.
    (For the original poster, canti levers is the "correct" answer.)
    TF
    "Don't those guys know they're old?!!"
    Me, off the back, at my first 50+ road race.
    Jan 2002
    Iirc. . .
    . . .you can run V levers with Canti brakes. This is batted around on the Cross board from time to time. The drawback is that Canti levers have less pull, so you have to run the pads super close to the rim to get decent braking power.
    When running Canti levers with V brakes you have the opposite problem. Too much pull and thus brakes that lock up so easily they are dangerous. Shimano V brake components come with a little warning about this. I've never heard of people trying to get around this by setting the pads further away from the rim. . .
    Travel Agents are another option that I have used with Canti levers and V Brakes.
    At any rate, if I were setting up a bike for a friend, I wouldn't fiddle around with novel braking solutions.
    Jan 2002
    So you are right. . .
    . . .about the V levers, come to think of it.
    Nov 2002
    Quote Originally Posted by czardonic
    These work by shortening the housing... they don't have a way to work as a stand alone lever because they don't anchor the cable. So this won't work. At least not with the 4 ro 5 brands of levers I have ever worked on. It's odd to explain but they don't actually grab the cable at all, so you can't use them by themselves.
    Russ
    Nov 2002
    Brian
    Since you will need a Cantilever Lever, you should try to pick up some NOS levers off the bay.... lots of great levers are floating around on there since most everyone now uses V brakes. Otherwise, I may have a set of Dia-Comp SS 7's in a box somewhere around the house... if I can find them, they are yours for the cost of shipping them.
    Russ
    NeoRetroGrouch
    Quote Originally Posted by russw19
    Russ
    In-line CX levers will work. The cable head just sticks out the back side (see pic - don't remember who's this is.), but they probably wouldn't fit the MTB flat bar. The way I would go is to find (like in my basement) a set of old Avid Single Digit MTB levers. They're adjustable on the fly. Like these: http://cgi.ebay.com/ws/eBayISAPI.dll...108903232&rd=1
    TF
  1. changing brake reach
    By J dubya in forum Components, Wrenching
    Last Post: 10-04-2004, 06:30 PM
  2. Installing 'cross brake levers
    By DanoK in forum Components, Wrenching
    Last Post: 09-13-2004, 01:46 PM
  3. Difficulty reaching brakes in drops
    By jumpin_joe in forum Components, Wrenching
    Last Post: 07-30-2004, 07:28 AM
  4. Replies: 4
    Last Post: 06-20-2004, 09:59 AM
  5. Top mount brake levers that work with full sized V brakes?
    By jrm in forum Components, Wrenching
    Last Post: 06-19-2004, 06:29 PM
