Broken Dura Ace Bottom Bracket Cup
Results 1 to 25 of 44
    Aug 2004
    My Dura-Ace 9000 Bottom Bracket cup cracked in half. I took it to one bike shop and they said they could not remove it. I will be taking it to Spokes etc. in Vienna Va, where I bought the frame to see if they can do anything with it. Any suggestions if they can't get the BB off. It is a 2000 Serotta Legend Ti frame so would hate to not be able to fix it. I live in Annandale VA.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Hard to say without seeing it. But a good mechanic should be able to get it out.
    Apr 2014
    I hope anti-seize compound was used when it was built.
    'brifter' is a lame word.
    Between a torch, a Dremel, and various hammers/chisels I've never lost that battle. As tlg says it's hard to know given the lack of a visual. Post some photos. Help us help you.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: nova_rider's Avatar
    Sep 2005
    Quote Originally Posted by stan01 View Post
    Loctite is typically used on bb shell.
    Sep 2005
    Quote Originally Posted by gwwilliams View Post
    Post some pictures. I'm in Falls Church, and have been riding/build Ti bikes since Indurain last won TDF. Be glad to take a look if needed.
    Aug 2004
    It has Loctite on it
    Quote Originally Posted by nova_rider View Post
    Aug 2004
    JPEG upload fails
    I tried to add a couple of pictures, with "Upload Photos" button but the upload always fails. Also tried to add image but didn't have any success with that either.
    Uhmmm...no. Grease or anti seize, never Loctite.
    Use an image hosting service like imgur.com. Dead simple...upload photos to imgur, click on image, click on BBCode in the column on the right, paste directly into your post here.
    Russian Troll Farmer
    Sep 2016
    ...or just reduce the size of your file so that it doesn't exceed the max allowed size...
    "L'enfer, c'est les autres"
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Particularly titanium...
    Sep 2011
    I say use a soft flame to heat up that bottom bracket really well up and remove the cup! heat will expand the outer bb shell and hopefully that will be enough for you to torque out the cup. Just don't force the issue too hard or else you might shred the bb threads!
    If that fails, then time to take out the dremel and cut up that damm cup up!
    Aug 2004
    Sep 2005
    Been using it on all my Campy UT cups for years. Not the permanent stuff, but 242 as I recall.
    https://youtu.be/fAHd2amwskU
    I guess Shimano recommends grease on theirs.
    Sep 2005
    This looks interesting. Did the shop made any attempts to remove this?
    Sep 2005
    Aluminum has greater thermal expansion than titanium. The cup is aluminum, so heating won't work. Need to go cold if anything.
    Never LocTite. Never.
    Never.
    Aug 2004
    Recommended by Serotta
    [QUOTE=cxwrench;5353939]Never LocTite. Never.
    When I first purchased the frame in 2000, I had 9 speed Dura Ace on it and the BB kept coming loose. After this happened several times Serotta recommended LocTite. I have had several BsB on it since then and have always used LocTite with no problem.
    Aug 2004
    Yes they had it for almost a week and then called and said that they did not feel comfortable doing it without damaging the frame.
    tlg
    tlg is online now
    May 2011
    Yup! Plus the frame has more thermal mass. It's going to suck the heat away from the BB. It'll never ever ever ever grow faster than the BB does, even if had a greater coefficient of thermal expansion... which it doesn't
    The proper method would be to fill a zip lock with ice water and stuff it inside the BB to shrink it. Or blast it with a co2 cartridge.
    Reputation: Srode's Avatar
    Aug 2012
    crushed ice with salt water even better
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    Oct 2013
    Take it to a machine shop with a lathe, a small one, he can lathe it out, but it's going to cost you.
    Don't use locktite, except for the lowest level on anything.
    BANNED
    Reputation: Tlaloc's Avatar
    May 2005
    Liquid Wrench
    OUCH! Soaking it in liquid wrench or some other penetrating oil might help.
    Sep 2005
    So I can assume what you've shown is not how it looked when it first broke? Were they able to remove the other cup?
  1. Is Dura-Ace crank compatible with Ultegra bottom bracket?
    By 1gunner in forum Components, Wrenching
    Last Post: 05-25-2006, 06:59 AM
  2. Replies: 4
    Last Post: 09-01-2005, 11:51 AM
  3. Replies: 2
    Last Post: 06-27-2005, 06:52 AM
  4. Shimano 7700/7701 Dura Ace Bottom Bracket
    By bikejr in forum Components, Wrenching
    Last Post: 05-11-2005, 07:45 AM
  5. Dura-Ace double crank on triple bottom bracket
    By PT in forum Components, Wrenching
    Last Post: 11-20-2004, 10:15 AM
