Building my new De Rosa Dual Question...
Results 1 to 3 of 3
    Breakin' Stuff
    Reputation: Flyingsquid's Avatar
    I'm getting a new De Rosa Dual frame in a week or so & have been accumulating the components (mostly Campy Record) to build it. I'll say straight off that this is a bit of an experiment for me, having only ridden Shimano stuff & not having much experience at all with the mechanics beyond regular bike maintenance. So time to get my hands dirty... with that in mind, I have a couple questions:
    1) Does anyone know if I will be needing a Clamp or Braze front derailleur?
    2) Are there different rear derailleur's for 9 speed & 10 speed? I bought a rear Derailleur (which I haven't received yet) but it made no mention of whether it was a 9 or 10 speed. I have since noticed on other websites an option to choose one or the other. Here is the link to the one that I bought:
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3661600704
    3) The crankset that I bought (FSA Team Issue Carbon) listed it as "9 Speed" . Can this crank be used with a 10 speed setup as well?
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3662139024
    Any help appreciated....
    Lonnie
    The derailleur shown is most certainly a 10-speed model.
    The crank should work fine with a campy 10 drivetrain, just be sure to get the 108mm ISIS bottom bracket that is required. The FSA Plainum Pro Ti is available at www.wisecyclebuys.com for $85.
    From the pictures, it looks like you need a clamp on derailleur, or you can also buy a braze-on adpater, but you need to know the diameter of the seat tube. Contact the place where you bought the frame for that information.
    http://www.sinclairimports.com/De_Ro...a_Home_04.html
    Nov 2001
    DeRosa Duals take a 34.9mm clamp-on front derailleur.
