Cable End Techniques
Results 1 to 24 of 24
    Feb 2006
    Bonjourno
    Do you solder? Glue? Tape? Crimp?
    TX
    duh tramp
    Reputation: Oxtox's Avatar
    Aug 2006
    crimp...
    found some gold end caps that exactly match the frame color.
    sweet.
    Reputation: nova_rider's Avatar
    Sep 2005
    Whatever you do, just don't leave too much extra hanging to ruin the look. 4cm max.
    'brifter' is a lame word.
    Soldering takes too long and pretty much every cable I use is stainless so that's a no. Tape is incredibly cheesy, so no. Glue? No. I use small crimps and like nova posted I cut the cable tail short.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2006
    I've been crazy gluing which works ok. Soldering is probably the best but I don't have an iron or torch and like them short and getting the heat to close to the DR's leaves me not feeling good. The next set I do I think I'm going to wrap with electrical tape so it doesn't unravel then glue it then take the tape off....
    May 2012
    Heat shrink tubing seems like it should work-would keep you from "losing" the cable end length whenever you install new housing but keep the old cable.
    Nov 2002
    The good thing about soldering is you can reinsert the cable into the housing without it fraying.
    Sent from my iPhone using Tapatalk Pro
    gazing from the shadows
    Jan 2003
    Back when I used to care, super glue (let dry) then a light crimp. The glue makes it easier if you want to pull and re-thread the cable later, since it usually holds the strands together pretty well after taking the crimp cap off.
    Since I realized I almost NEVER pull and re-use cables, I just crimp now.
    Reputation: Wetworks's Avatar
    Aug 2012
    Quote Originally Posted by Oxtox View Post
    crimp...
    sweet.
    This, always. Should be part of the rules at this point.
    May 2011
    Used to solder all the time; it has the cleanest look. Unfortunately, as CX says, cables these days are pretty much all stainless so that doesn't work anymore. I have an assortment of colored end caps that match my various bikes.
    Well, you know, that's just, like, your opinion man. - The Dude
    Feb 2006
    Ya, obsessing no doubt...you know, the bike, my “perfect” world thing. They’re just such an elegant machine.
    I found the “Heat Shrink Buddy” on eBay. Imagine, someone that’s a heat shrink expert. Double wall adhesive heat shrink. Who’d of thought?
    The plan is when I cable the project Paul’s Klampers and Ultegra R8000 cables I’m going to apply a tube then cut. I just want to avoid that initial unravel that I get every time and never seems to go back 100%. The crimp on’s seem to fall off sooner or later on a ride. We’ll see...
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Wow, didn't know anybody did anything other than crimps. I learn something new every day!
    Nov 2002
    Quote Originally Posted by OldChipper View Post
    If you use acid flux, the solder will wet to the stainless cable.
    Quote Originally Posted by saddle tramp View Post
    I rarely have cables unravel, generally that's caused by using a dull cutting tool. I don't even use cable cutters, instead I use Knipex dikes (diagonal cutters), they work so well cable cutters aren't needed. I only use those on shift housing.
    Banned Sock Puppet
    May 2014
    I can't say I,ve ever had a problem with unravelling using cable cutters as long as I crimp the cable immediately. Dikes are the worst for that.
    Nov 2014
    Solder, then crimp. I've had both fail and I hate unraveling cables.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Jagwire non-crimps for the win. Just push them on. Pull them off and re-use them. I've had the same set for years.
    There's some other brands too that are reusable.
    https://www.amazon.com/Flying-Wheels...dp/B072FNN338/
    Reputation: ogre's Avatar
    Dec 2005
    Those look heavy and non-aero 🙂
    Russian Troll Farmer
    Sep 2016
    +1. I've seen people who do this who never consider using flux. That's the difference between actually TINNING the ends or just making a huge mess with only solder.
    "L'enfer, c'est les autres"
    tlg
    tlg is online now
    May 2011
    Yup. I've soldered SS cables with Flux. No problem.
    Frog Whisperer
    May 2003
    Sorry bud, but you are incorrect, stainless is easily soldered with the right flux and silver solder. For reference, stainless lugged frames are silver brazed or soldered together. HOWEVER.... a crimp is still a good idea. An approximately 1.5 mm cable cut clean and soldered can leave a puncture wound the depth of the cable end. Guess how I know.
    Some cables are either silicone or Teflon treated. THAT makes them nearly impossible to solder.
    Of course I'm sure...that doesn't mean I'm right.....
    "There's no sense being stupid unless you show it."
    Jan 2020
    Superglue and black crimps for me. I would like to solder but seems to be a tad labour intensive.
    Quote Originally Posted by Touch0Gray View Post
    Right you are.
    Nov 2002
    A bit of sandpaper removed the black Teflon coating off the end of the cable for me, and I was able to solder it. Yes, agree on getting stuck by the soldered cable end.
    I tried Superglue once, but it didn't work.
  1. Replies: 3
    Last Post: 04-03-2015, 02:08 PM
  2. Help! shifter cable end stuck in cable stop.
    By norman.j.singh in forum Components, Wrenching
    Last Post: 12-11-2013, 12:20 PM
  3. Shifter Cable Broke - No sign of the cable end
    By VinPaysDoc in forum Components, Wrenching
    Last Post: 03-27-2008, 06:28 PM
  4. cable end prep with cable splitters
    By canamdad in forum Components, Wrenching
    Last Post: 12-22-2006, 08:14 PM
  5. Breathing techniques?
    By RemingtonShowdown in forum General Cycling Discussion
    Last Post: 02-19-2004, 09:59 PM
