Cable housing length - short on purpose?
Results 1 to 8 of 8
    Aug 2013
    Just wondering if anybody ever cuts their cable and brake housings a bit shorter than recommended for aesthetic purposes or have seen pro bikes set up like that?
    'brifter' is f'ing stupid
    Of course. It's all subjective. I've seen short, what I consider correct, and long. I'm sure some guys cut short because they think it looks better. Does it really matter?
    #promechaniclife
    Aug 2013
    Even short to the point where you can't turn the handlebars all the way?
    Reputation: nova_rider's Avatar
    Sep 2005
    Any bike that has these cut too short is a sure sign that the bike belongs to a poseur, or is looked after by a novice mechanic.
    Sent from my moto x4 using Tapatalk
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by nova_rider View Post
    Any bike that has these cut too short is a sure sign that the bike belongs to an amateur, or is looked after by novice mechanic.
    Bingo!
    If 'aesthetics' is what you're after, why would you make your bike look un-aesthetic to anyone who knows anything about bikes.
    Quote Originally Posted by 5DII View Post
    Psstttt.... that's not aesthetically pleasing. People will probably look at you like you don't know what you're doing.
    If you want to look cool... just make your cables the proper length.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    When I cut new housings, I always make them just a bit longer than the originals.
    Remember, if they are too long, you can make them shorter. If they are too short, you can't make them longer.
    "With
    -- DCGriz, RBR.
    No matter how long the old ones were? Do you take a look at the old ones are just go ahead and cut the new ones so they're longer? I never bother w/ the old housing, I just cut the housing the correct length.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    And what is the "correct" length?
    Yes, I use the old housings as a guide. Naive as it may sound, I assume the old housings are close to the correct length - on a bike I bought new of course.
    "With
    -- DCGriz, RBR.
  1. Full length cable housing without cable stops
    By alxrmrs in forum Components, Wrenching
    Last Post: 10-13-2016, 04:54 PM
  2. Can you use a shifter cable housing as a brake housing?
    By bmwjoe in forum Components, Wrenching
    Last Post: 04-07-2013, 11:42 AM
  3. Internal Brake Housing...Cable Housing....
    By spepic in forum Components, Wrenching
    Last Post: 07-14-2008, 05:40 PM
  4. Cable housing length?
    By harvey in forum Components, Wrenching
    Last Post: 06-22-2005, 12:32 PM
  5. Cable housing length?
    By harvey in forum General Cycling Discussion
    Last Post: 06-21-2005, 05:01 PM
