calling CX wrench - DA 9000 hub question
Results 1 to 5 of 5
    Feb 2005
    While repacking my DA rear hub, I popped out the rubber seals to wipe the bearing race and can't seem to get it back correctly.
    Is this correct? The seal with the metal ring goes on the NDS with the rubber side out and the rubber seal with the deep channel goes on the freehub side with the deep channel facing out and the flat side facing to the inside next to the bearings. I can't seem to get the drive side seal to seat correctly. As a result, it sits unevenly and I can't get the bearing tension correct.
    I checked and compared it to my other DA 9000 rear hub and the only difference seeems to be the drive side rubber seal.
    What am I missing or doing incorrectly? I have been repacking hubs since the days of Campy 5 speed so I have done this a few times.
    Feb 2005
    never mind, took a break, checked Shimano tech documents and went back, the DS seal went right in and straight - all good now.
    'brifter' is f'ing stupid
    Glad I could help
    #promechaniclife
    Feb 2005
    After posting I asked myself " what would CX say? " I'm sure you wish it was that easy with your paying customers. thanks
    Quote Originally Posted by steelbikerider View Post
    You have no idea. Good job on figuring it out and getting it done.
    #promechaniclife
  1. DA 9000 rear hub clicking
    By 5DII in forum Components, Wrenching
    Last Post: 10-13-2014, 07:24 PM
  2. Dura Ace WH-9000-C24-TU vs WH-9000-C24-TL
    By Philhumphrey in forum Wheels and Tires
    Last Post: 02-22-2014, 12:50 PM
  3. Any trouble running DA 7950 Cranks with DA 9000?
    By SB-Rider in forum Components, Wrenching
    Last Post: 11-08-2012, 03:04 PM
  4. dah da da da da da da da da...tequila!
    By Bocephus Jones II in forum The Lounge
    Last Post: 08-14-2010, 05:54 AM
  5. Da...da...da....da...da...DA!
    By DrSmile in forum The Lounge
    Last Post: 10-02-2008, 03:11 AM
