• 08-06-2019
    typhoon05
    Campagnolo brake barrel adjuster? Which to turn?
    After having Shimano equipped bikes for years im just wondering which part I should be turning to adjust the brakes, is is the silver bit at the top or the round disk with like a rubber ring in the middle? Link to what it looks like below: if you turn the rubber disk thing it has like notches underneath it?
    https://247cycleshop.com/campagnolo-...-adjuster.html
  • 08-07-2019
    nova_rider
    Turn the rubber ring, just make sure it settles into the notch once you're done. The notch prevents the adjustment from walking.
  • 08-07-2019
    velodog
    I don't want to come off like a dick, but if you couldn't figure out a barrel adjuster, maybe you should have someone else do your bicycle maintenance.
  • 08-07-2019
    cxwrench
    Quote:
    Pretty much...try it and see what happens.
