Campagnolo brake barrel adjuster? Which to turn?
Results 1 to 4 of 4
    Feb 2019
    After having Shimano equipped bikes for years im just wondering which part I should be turning to adjust the brakes, is is the silver bit at the top or the round disk with like a rubber ring in the middle? Link to what it looks like below: if you turn the rubber disk thing it has like notches underneath it?
    https://247cycleshop.com/campagnolo-...-adjuster.html
    Reputation: nova_rider's Avatar
    Sep 2005
    Quote Originally Posted by typhoon05 View Post
    Turn the rubber ring, just make sure it settles into the notch once you're done. The notch prevents the adjustment from walking.
    Reputation: velodog's Avatar
    Sep 2007
    I don't want to come off like a dick, but if you couldn't figure out a barrel adjuster, maybe you should have someone else do your bicycle maintenance.
    Too old to ride plastic
    'brifter' is a lame word.
    Pretty much...try it and see what happens.
    I work for some bike racers
    and a bunch of skateboards
  1. Barrel Adjuster or Cable adjusting bolt unit for Ultegra brake
    By zeli0040 in forum Components, Wrenching
    Last Post: 08-13-2013, 08:11 AM
  2. Routing Front Brake Without Barrel Adjuster
    By lml1x in forum Cyclocross
    Last Post: 06-07-2007, 08:31 AM
  3. Brake Caliper Adjuster Barrel Won't Move
    By S2H in forum Components, Wrenching
    Last Post: 04-25-2006, 07:07 PM
  4. HELP! I need a barrel adjuster!
    By P-Funk in forum General Cycling Discussion
    Last Post: 06-16-2004, 11:10 AM
  5. Headtube Cable Stops - What Kind of Barrel Adjuster?
    By JBF in forum Components, Wrenching
    Last Post: 05-25-2004, 11:12 AM
