Campagnolo ErgoPower rebuild
Results 1 to 8 of 8
    Sol
    Sol is offline
    Jan 2020
    I recently disassembled both shifters, because I was having problems with inaccurate shifts.
    In the process I found that one of the g springs was bent, and after tinkering with it, it broke.
    Now, given the fact that both shifters are completely disassembled, and since I am doing this repair the first time, is there anything else that would be worth replacing?
    Reputation: nova_rider's Avatar
    Sep 2005
    Which group and what year is this? What's the condition of the index gear? How about the index spring carrier?
    Sol
    Sol is offline
    Jan 2020
    Chorus 10 speed, 2006. Index gear and spring carrier seem to be in good shape. I will post a picture tomorrow, currently its midnight and the lighting is off for shooting pictures.
    'brifter' is f'ing stupid
    Springs and spring carrier. The index rarely if ever wears out or breaks. The springs will wear a bit, the major issue is the carrier...which is why those parts are packaged in a kit.
    #promechaniclife
    Sol
    Sol is offline
    Jan 2020
    I imagine that the wear on the spring is normal or should I replace that?
    There are some indentations on the spring carrier on the right shifter. How bad is that?
    That spring can wear/break but the ones you should be concerned w/ are the ergo springs, or 'G' springs. The spring you have shown doesn't affect shifting performance...unless it breaks.
    #promechaniclife
    Sol
    Sol is offline
    Jan 2020
    Got it thanks. That wear on the carrier is something I should be concerned about or I can keep using it?
    Replace it. That little bit of wear will make the shifter feel mushy and not hold gears as it should.
    #promechaniclife
  1. Rebuild 11s Ergopower; Grease?
    By natedg200202 in forum Campagnolo
    Last Post: 05-28-2015, 05:39 AM
  2. Centaur Ergopower or Ergopower Ultra Shifters
    By pulser955 in forum Campagnolo
    Last Post: 06-07-2010, 11:22 AM
  3. Attempting an Ergopower rebuild, any tips?
    By brewster in forum Campagnolo
    Last Post: 01-17-2008, 05:07 AM
  4. Ergopower rebuild - brake lever pivot removal
    By Fr Ted Crilly in forum Campagnolo
    Last Post: 09-02-2007, 11:19 AM
  5. Campagnolo ergopower 9s and Ultegra cassette - compatible?
    By KarbonPol in forum Components, Wrenching
    Last Post: 04-04-2006, 04:31 AM
