• 07-11-2020
    sheepherder
    campagnolo record 12 speed chainset questions
    Just making sure I don't need any sorts of washer for install? Nothing but the chainset and crank arm came in the box
    Also I have a super record 11 speed bottom bracket. Can the new 12 speed record be used with it? It says right on the bottom bracket for use with super record only but has that changed with the 12 speed groups? Bottom bracket also has the retaining clip
    thanks
  • 07-12-2020
    DrSmile
    The wave washer comes with the bottom bracket cups, you will need to install it on the non-drive side. Super record bottom bracket cups lack the seals of the non-SR bottom brackets but can be used with any crankset (obviously the bearings can get wet more easily without the seals). You can also install seals on Super Record BB cups, but you'd need another bottom bracket to take the seals from (or buy them OC-RE002, but it's almost the same price to buy the whole bottom bracket). All UT bottom brackets are interchangeable between 10, 11, and 12 speed. As long as it's not Powertorque and you have a BSA bottom bracket you should be fine.
  • 07-15-2020
    sheepherder
    Quote:
    Thanks, that helped.
