campagnolo record 12 speed chainset questions
Results 1 to 3 of 3
    Mar 2012
    Just making sure I don't need any sorts of washer for install? Nothing but the chainset and crank arm came in the box
    Also I have a super record 11 speed bottom bracket. Can the new 12 speed record be used with it? It says right on the bottom bracket for use with super record only but has that changed with the 12 speed groups? Bottom bracket also has the retaining clip
    thanks
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    The wave washer comes with the bottom bracket cups, you will need to install it on the non-drive side. Super record bottom bracket cups lack the seals of the non-SR bottom brackets but can be used with any crankset (obviously the bearings can get wet more easily without the seals). You can also install seals on Super Record BB cups, but you'd need another bottom bracket to take the seals from (or buy them OC-RE002, but it's almost the same price to buy the whole bottom bracket). All UT bottom brackets are interchangeable between 10, 11, and 12 speed. As long as it's not Powertorque and you have a BSA bottom bracket you should be fine.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Mar 2012
    Quote Originally Posted by DrSmile View Post
    Thanks, that helped.
  1. Replies: 16
    Last Post: 09-01-2014, 05:17 AM
  2. Campagnolo Super Record Ti' Chainset RIDER WEIGHT LIMIT ?
    By bolo yeung in forum General Cycling Discussion
    Last Post: 12-07-2013, 10:09 PM
  3. Record CT Chainset & Record Cassette w/DA Shifters/Derailluers
    By mcquill in forum Components, Wrenching
    Last Post: 07-20-2007, 01:55 PM
  4. 10 speed chainset, 9 speed chain; problems?
    By t5rguy in forum Components, Wrenching
    Last Post: 10-28-2005, 04:55 PM
  5. New B/B For NOS Campagnolo C-Record Chainset
    By DannyBoy in forum Components, Wrenching
    Last Post: 09-01-2004, 12:15 PM
