Campy 11sp front derailleur with S-7800 shifters
Results 1 to 6 of 6
    Reputation: pigpen's Avatar
    Sep 2005
    Will it work.
    Going on a cross bike with a 46 outer ring. Small jump in gears might help.
    Or is it a bust.
    thanks
    Adventure Seeker
    Reputation: Peanya's Avatar
    Jun 2008
    Even though it is narrorwer than the 10sp, it should be just fine.
    I have a single track mind
    Sep 2010
    How much cable pull does a Shimano shifter have? How much does a Campy derailleur need? These are not mix and match parts built on some sort of shifting standard.
    If it did work, it would be pure, dumb luck. Use a Shimano, FSA or Microshift.
    Apr 2005
    The pull will be just fine, that won't be the issue. The issue will be it's width. I would try it just to find out.
    Adventure Seeker
    Jun 2008
    Oh, if you do try it, be warned that the campy gods might smite you.
    Sep 2005
    Sort of like the way I use Dura Ace pedals on a otherwise Campy bike.
    Thanks, going to give it a shot.
