Campy 8 speed ergos, 10 speed RD, 8 speed cassette
Results 1 to 6 of 6
    Jan 2003
    Anybody know if this combo works:
    1) Campy 8 speed erogs
    2) 10 speed rear der
    3) 8 speed Campy cassette
    cs1
    cs1 is offline
    Reputation: cs1's Avatar
    Sep 2003
    Quote Originally Posted by lml1x
    Campy changed the actuation ratio sometime in 2000. So all 8 sp and pre 2000 9 sp use the old style rear der. Contrary to what some say mixing doesn't work well. Add that to fact that 10 sp rears are too narrow to fit an 8 sp chain. Jtek #1 will make that combo work. Contact them and they will tell you the back door fix. Good luck
    1995 Waterford 1200
    1999 Waterford RSE-11
    Plus a host of old bikes too many to list.
    duh...
    Jan 2005
    find an old 9 der
    Quote Originally Posted by mikagsd
    Fat tire Fred....you are the bike god of the universe and unless someone agrees with your reasoning they are just plain stupid
    Aug 2008
    No, it won't work. I tried it even though I knew better. You'll need to find an old der on e-bay or something.
    Oct 2009
    Yes, it will work if you add a Jtek Shiftmate type 1. The ratio between the actuation ratios for 8 speed and 10 speed is 1.07, the type 1 ratio is slightly less IIRC.
    It will not work quite as well as the 8 speed rear derailleur would. For best results run a 9 speed chain and either replace or shim the derailleur pulleys by 0.2mm.
    cs1
    cs1 is offline
    Sep 2003
    Quote Originally Posted by Mark Kelly
    Didn't I just say that in #2?
    1995 Waterford 1200
