Campy Crankset with Shimano Drive Train?
Results 1 to 13 of 13
    May 2005
    Yes, I know it's sacrilege ... I'm just trying to make use of parts I have.
    I'm looking to combine a Campy UT crankset with a new Shimano DI2 Ultegra drive train. I actually have two Campy cranksets that I could use, a SR11 53/39 or a Record 10 53/39.
    Any reason why using one of the Campy cranksets wouldn't work well?
    likes to eat donuts
    Reputation: piano,piano's Avatar
    Jun 2005
    because it's wrong
    Would you take your Toyota to a Honda dealership for repairs?
    “The secret of life is honesty and fair dealing. If you can fake that, you've got it made.”
    -Groucho Marx
    Sep 2008
    Don't know what this has to do with Honda / Toyota - after all, these are only bike parts.
    I would think either Campy crank will work fine.
    Apr 2010
    Don't do it.
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    It works fine...I've done the opposite, too -- a nice pair of Dura Ace cranks in my parts bins coupled with a full Campagnolo drivetrain. Sure, it makes the "style police" get up in your business, but who cares?
    "Luminous beings are we...not this crude matter!"
    pmf
    pmf is offline
    I see no reason why this won't work. The Campy 11-speed chain is narrower than the Shimano 10-speed, so you might want to go with the 10-speed Campy. A 10-speed chain would definitely fit on a narrower 11-speed ring, but there might be some extra room for movement and noise. I guess there's one way to find out ...
    ef the style police.
    it may work but...
    Quote Originally Posted by Hillen View Post
    is it really worth being condemned to eternal damnation?
    Mar 2011
    There is no reason it shouldn't work. Best way to know it is to try it. It's a 15minutes job. If the shifting is perfect, keep it.
    Once you have installed either one, send me the other one for the great advice I gave you. I'm in need of crankset since I migrated one from my road bike to my cx bike.
    I like mixing parts. It makes people talk in the group rides.
    classiquesklassieker
    Reputation: orange_julius's Avatar
    Jan 2003
    I don't have Shimano, but if I recall correctly, Shimano double FD has more travel than a Campagnolo double FD. It could be that the distance between Shimano (double) chainrings - the spacing - is greater than that for Campagnolo.
    That said, if it were true, then the Di2 system will have to be adjusted for the Campagnolo chainring spacing.
    It works fine and it will work fine with 11 speed, too.
    I have a SRAM bike, long story why I have that bike, and I put my record 11 speed crank on it - I did it only because I ride 177.5mm and thus put on my campy - works fine and saves the bike a LOT from the ugly SRAM crap.
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Admittedly only guessing here, but based on what I see and know, it should work fine. I'd guess you'd have a bit less trouble with an 11s chain on the 11s set, but other than that, should be pretty seamless.
    A good habit is as hard to break as a bad one..
    Dec 2011
    I rode a few weeks with a campy chorus cranck on my dura ace; it fitted perfectly.. The campagnolo crancks are very simular to the fulcrum ones..
    Reputation: thebikingcello's Avatar
    Feb 2011
    I have seen it done with a Record 10 speed with a ultrgra/dura ace build. he wanted to get campy, but can swing a few grand all at once, so he parted it out.
    I say there is nothing wrong with it
    Bikes:
    Felt F95 2011: my main road ride
    Jamis Dragon 29 Sport 2011: my main MTB(Steel is Real)
    Raleigh Record 1976: Single speed in the making
    Possible Fuji cross frame I might get... and paint...
  1. Campy Chorus crankset w/shimano drive
    By Reinbag in forum Components, Wrenching
    Last Post: 05-10-2010, 09:08 AM
  2. Shimano drive train replacements
    By xrazer in forum Components, Wrenching
    Last Post: 10-06-2009, 03:30 PM
  3. Dura-Ace drive train: Campy or Shimano cranks?
    By framed in forum Components, Wrenching
    Last Post: 04-21-2009, 11:46 AM
  4. campy crankset w/ shimano drive train
    By buddhistwithafancybicycle in forum Components, Wrenching
    Last Post: 10-03-2006, 02:43 PM
  5. Campy Record Shifters With Shimano Drive Train
    By Zeno in forum Components, Wrenching
    Last Post: 06-02-2004, 07:40 AM
