Campy SR Shifting Poorly, Stumped
Results 1 to 13 of 13
    Mar 2019
    Question Campy SR Shifting Poorly, Stumped
    So the 2015-2017 Super Record Groupset I'm building up currently isn't shifting right. It shifts slowly in both directions, especially with the extreme ends.
    Heres the build:
    - Campy SR 2015-2017 11 speed shifters and derailleurs, used but appears brand new (not a single scratch on any of the pieces)
    - Brand New SRAM Red XG-1190 11s Cassette 11-25T
    - Campy SR 2017 11 speed Crankset, used but also near flawless.
    - Brand New Shimano SP41 Housing
    - Brand New Jagwire Campy Cables
    - Brand New Campy Record 11s Chain
    - Brand New Bitex RAR9 11s Hub
    Symptoms:
    - Shifts to largest just fine, but doesn't shift to second largest. Shifting again shifts flawlessly to 3rd largest.
    - Shifting improves if I shift repeatedly between 2 sprockets (e.g. 1-2-1-2-1), but only for those two, kinda like worn housing
    - Shifting in the small range of the cassette is just poor in both directions.
    - Shifting is ​ok in small chainring. However, disconnecting the FD cable entirely does not solve the issue.
    - A FIRM shift-and-hold will achieve the shift, but lighter touches as one would normally operate often fail to shift.
    - RD cage looks visually crooked, but how's that possible? The thing is carbon fiber and doesn't show any wear (Der. hanger is straight)
    Here's what I've tried:
    - Hanger is straight
    - Housing is all brand new Shimano SP41, ferrules are new
    - B tension is properly set
    - Cables are new, Jagwire Campy Specific
    - RD pivots have been lubed and worked/wiggled thoroughly by hand.
    - Shifter has been rebuilt from scratch, shift plate does indeed have the letter A on it, as does everything else in the drivetrain.
    - Reinstalled cassette, made sure everything was centered and seated properly
    - Limit screws are properly set
    - Spent more than an hour trying to index the thing, still shifts like crap
    - Tried an external, full-housing, direct shifter-to-RD cable run, also with brand new SP41 housing, same ****.
    - Chain length is correct according to Campy standards, was just cut and built up.
    Could the SRAM red cassette be the culprit? I thought it was well established that 11s cassettes were all interchangeable. Campy chain isn't directional IIRC, there was text on both sides and plates were symmetrical and identical. Could it possibly be the Shimano SP41 housing I used? Must I used campy housing too?
    I'm stumped and down... Did I miss anything?
    Thanks in advance.
    'brifter' is a lame word.
    Sounds like something is causing friction and that's messing up your shifting. I agree that all 3 brands are so close that cassettes are interchangeable. Could be a simple kink in the cable where it's inside the housing. I wouldn't think the brand of cable/housing would matter this much. Hard to say w/o seeing it.
    I work for some bike racers
    and a bunch of skateboards
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Cheap Bitex hubs....is the FH->dropout face within spec? Outside face of the hanger to outside of the 1st gear should by 10.2 to 12.2mm max.
    You say 2015-2017...are all the parts labeled "A"?
    Feb 2002
    Quote Originally Posted by hihihi8 View Post
    Heres the build:
    Symptoms:
    Thanks in advance.
    When you execute a shift, does the RD upper jockey pulley align properly with each of the cassette cogs? Does it "over-shift" just slightly before aligning? A careful observation of the actual shift might provide a clue.
    Jan 2005
    Is the cable getting hung up in the bottom bracket cable guide? That gave me fits a while back
    Sent from my Moto G (5) Plus using Tapatalk
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    I second the bottom bracket cable guide, crud tends to collect there, but you said you've already run the cable direct. Another thing to check on the shifters is to pull back the shifter covers and look for the little Y shaped guide inserts, often there is corrosion on the cables there that prevents the cables from sliding freely. You can also check whether there is play in the RD at the attachment to the hanger, that had me stumped recently. Look from behind and top at the RD and see if the pulleys line up correctly.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Mar 2019
    Thanks for all the ideas!
    Yes, it does overshift. In fact, when I get it to shift well in the smaller cogs, it sometimes overshifts too much on the larger cogs, bumping the chain up to the next largest before dropping it back down.
    Yes, the shifter der. combo was bought together. Everything's got an A on it, including the shift ratchet plates inside the shifters. However, you did get me when you mentioned the hanger distance. My cassette/hanger distance measured 12.8-12.9. However, even after I put a 1mm spacer behind the cassette to bump it out a bit, there was no improvement in shifting (there is dangerously little spline engagement on the last cog, i would not ride it like this, but did it out of curiosity)
    I tried running it direct shifter-to-RD really short housing (total length 1 foot/30cm), and the shifting improved drastically. It would actually make all shifts in a manner one would expect of SR. That, however, raises the question of: is it the housing, or is it something else that's slightly sticky, and was made worse by the long-ish cable run? When I run internal routing though, there is no housing so whatever it is, it's pretty sensitive to small changes.
    Quote Originally Posted by DrSmile View Post
    Pulley cage is pretty tight and doesn't wobble or exhibit play. The hanger is straight and was straightened/double checked when I was fiddling with it trying to get it to work, however the cage doesn't look very vertical, but I can't imagine how the cage could be bent, as the RD itself is mostly carbon fiber and doesn't have a scratch on it. The BB cable guide is clean, and shifting sucks even with full-length full-housing.
    On the other hand, thanks for bringing up the Y-shaped cable guide! I had not checked that, while it's not filthy, there is some black residue in that I'll clean out when I next work on the bike. I'm also going to try the alternative route on the Y-guide. Right now, I have the cable coming out at an angle (along the front of the bars) instead of following the outboard side of the bar. Maybe that'll change something!
    Anyways, thanks for the help!
    Quote Originally Posted by stlutz View Post
    That was my first thought. I don't know how to heck it happens but gel or energy drink can get down there and it can be worse than it looks. I assume it was gel or energy drink anyway that make it really sticky a few times I've checked on that.
    For what it's worth: I could never get Sram cassettes to work all that well with everything else being shimano and the identical set up working just fine with a shimano cassette. It was good enough to use but not great.
    So while Sram cassette and campy chain both 11 speed may not be a 'compatibility' issue per se it may be that Sram cassettes are just not that great. Expensive thing to check on, but cassettes don't last forever and it's always nice to have other gear options haging around so probably worth giving a campy cassette a try.
    Mar 2004
    What's the frame? Start on the smallest cog big ring take the tension off the cable make sure the the top pulley is lined up with the cog. Set the cable with the adjuster around half way. go from smallest to the next back and forth adjusting cable tension to get the shift with the click no more no less and see how that works.
    You did replace the cable after you did this, right?
    Mar 2019
    Was going to, but I couldn't find even the tiniest flaw in that cable since campy's clamp is flat and I was pretty light on the clamping torque. FWIW, it shifted damn well with that super short cable run, and that was the last thing I tried before calling it a day, so the cable was 'pristine' prior to that too.
    Mar 2004
    It is odd it worked fine with the short run. I would think if it were the cassette it would shift poorly regardless. I'm assuming you unwrapped the bar when you did the direct route? Maybe the cable casing isn't set in the shifter. Is that thing landed firmly?
    Mar 2019
    Quote Originally Posted by mackgoo View Post
    I double-checked that before I posted my first post too, just forgot to list it under the things I had tried. I retaped the bars once, making sure to jam the housing in as I taped them in place, but to no effect either
  1. Campy SR Shifting Problems Need Advice
    By gofast2wheeler in forum Campagnolo
    Last Post: 04-21-2017, 08:48 AM
  2. Campy SR 11 shifting with shimano SRM cassette *update*
    By drrick97 in forum General Cycling Discussion
    Last Post: 03-23-2014, 04:39 PM
  3. poorly shifting ultegra 6700
    By Smokeydave in forum Components, Wrenching
    Last Post: 12-24-2011, 07:01 PM
  4. SLC SL Campy SR 11 shifting issues
    By RidingAgain in forum Cervelo
    Last Post: 04-11-2010, 04:36 PM
  5. Colnago w/ Campy SR and Vitus w/ Campy SR
    By tracke30m3 in forum Retro-Classic
    Last Post: 08-20-2008, 04:50 PM
