Can Shimano 7800 "Deep Spline" freehub body be replaced with standard spline?
Results 1 to 3 of 3
    Jun 2008
    I have a friend with the Dura Ace 7800 "Deep Spline" freehub body.
    He'd like the option of running the SRAM cassettes as they do have an 11-28 (yea, I know the new D/A has an 11-28, but only in NEW D/A).
    Can the freehub body on D/A 7800 hubs be replaced with the Freehub body for 7850?
    Thanks in advance!
    Old and Fixed, Moderator
    Jan 2002
    From what I've seen, no it cannot....The freehub body/hub interface is different on each model.
    I have great pic at home that shows the connection of the 7700,7800, and 7850...I'll post if tonight
    Dave Hickey/ Fort Worth
    No!
    There is no compatibility. If you really want that crappy shallow spline, you can take the cassette body to a machine shop and have the splines turned down. It won't be long before the cogs wear grooves into the soft aluminum, however. The shallow splines need a harder material to work properly.
    Apparently there were problems with Shimano's 7800 hub redesign. It was abandoned after 2 years with the 7850 model that returned to the old design and used Ti to save weight on the cassette body.
