Can you break a chain at the same spot twice?
Results 1 to 21 of 21
    Mar 2012
    I removed the pin at the same spot twice on my 10 speed chain. I did use a new pin.
    Is this okay?
    'brifter' is f'ing stupid
    Quote Originally Posted by sheepherder View Post
    Is this okay?
    No. Dibs on your stuff.
    #promechaniclife
    Dec 2006
    A second vote for no. The flared shoulders on the pin will damage the link when you drive out the pin, weakening the link. Replace a small section of the affected chain and use a couple new pins and you should be all set.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Third vote for hell no.
    Quote Originally Posted by Peter P. View Post
    Or just use a quick link.
    Feb 2002
    4th vote for hell no. 2nd vote for quick links.
    Reputation: OldZaskar's Avatar
    Jul 2009
    Literally "LOL"ed. My wife looked over and said "What?"
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    "You must spread some Reputation around before giving it to cxwrench again."
    "5."
    "I'll stay."
    "I suggest you hit, sir."
    "I also like to live dangerously."
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    Just make a chain made only out of quicklinks. Super easy to clean, super easy to shorten and lengthen!
    Maybe a little pricey, heavy and noisy but who cares?
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Russian Troll Farmer
    Sep 2016
    Wow, somebody thinks you can still re-use chain links? Maybe on a 6-speed chain, but NEVER on a 10-speed chain! Have fun when it fails on your next climb!
    "L'enfer, c'est les autres"
    Chain links? Who's talking about links? OP pushed a pin out and then put a new pin the same spot. As we all (excepting the OP) know this is a big no-no.
    #promechaniclife
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Go on a 100 mile gravel ride and get back to us.
    Oct 2013
    I reuse chain links all the time, no problem!
    BANNED
    Sep 2011
    A little elaboration on this if you will. Connecting links, Shimano links with connecting pins pushed through them or what? Your post adds nothing to this thread (which really was over at post #2) without some explanation.
    Oct 2013
    chain links... = master links consists of link with posts, a covering link and a spring clip to hold the covering link on. Can be removed and reinstalled on the same chain with a pen knife & small plyers.
    chain pins = shimano standard connection consists of standard chain and some ridiculous pin that you shove in and break 1/2 of it off to connect the 2 chain ends. Requires a special tool for removal and reinstallation. oh yea, cannot be reused and the link you had it in can't be reused... so your pretty screwed if your trying to use the same chain.
    2 completely different methods, goggle is your friend.
    also I only put out about 500w max ever, so this may not work @ pro level, or 'A' group level!
    BANNED
    Feb 2005
    Lay off the gummies, maaaan
    No, there are not any modern drivetrains that use the 'old/moto' style 'master' link. They all use either the pin or a quick link.
    No, the pin does not require the use of any 'special' tool, just a normal chain tool. And you're definitely not screwed if you try to reuse a chain that you've taken off. You just don't push out the joining pin...any other pin is fine and the chain can be rejoined using the 'special' pin.
    "Google is your friend"
    #promechaniclife
    Oct 2013
    Once you use a quick link.... a chain tool is a 'special' tool.
    Everything else I'm guilty, I just got back from a ride, so I was a little hyped up. I forgot that they called them 'quick' links & I get my moto's & other bikes mixed up a LOT.
    BANNED
    I still can't believe you think a chain tool is 'special' in any way. You still have to size the chain correctly no matter how you choose to join it.
    #promechaniclife
    Oct 2013
    Well it is kinda special, it's in your tool box and can only be used for 1 thing. Now in my tool box I have a chain tool and some pipe wrenches, 6"/12"/16"... I got everything covered!
    I guess I do use it for sizing a new chain. ....so ah.... you're right again! and a bonus apostrophe!
    BANNED
    No hammer?!?
    #promechaniclife
    Reputation: ogre's Avatar
    Dec 2005
    No hammer?!?
    Well, its appropriate to note that Duriels post didnt quite make the mark that was it's intention, but you're response was spot on.
  1. almost got killed twice in the same ride
    By nissan_clif in forum General Cycling Discussion
    Last Post: 06-26-2011, 12:45 PM
  2. Can you use a regular Chain Break on new 10sp Chains?
    By Rodder07 in forum Components, Wrenching
    Last Post: 03-18-2010, 05:56 PM
  3. Wheel going out of true at the same spot
    By cchough in forum Wheels and Tires
    Last Post: 09-10-2009, 06:42 PM
  4. Racing twice on the same day
    By lithuania in forum Cyclocross
    Last Post: 09-19-2008, 11:40 AM
  5. Replies: 9
    Last Post: 01-03-2005, 01:46 AM
