Can't figure out whats making this racket.
Results 1 to 25 of 34
    Mar 2019
    https://www.youtube.com/watch?v=bUo5BDhwydM
    I have indexed the gears to the best of my abilities and they shift fine. Checked RD and FD. Nothing rubbing. If I take the chain off and spin the crank and the rear wheel no such noise. What could be causing this?
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    B-Tension screw. Your rear derailleur pulley is too close to the cassette.
    Mar 2019
    I've extended the screw out completely and its still the same unfortunately.
    tlg
    tlg is offline
    May 2011
    Quote Originally Posted by Hulldown View Post
    Well then you're still doing it wrong. Backing it out moves the pulley closer to the cassette. You want it farther away.
    Mar 2019
    Just did that and tried it over a range. Still there
    Mar 2019
    If I push the bottom pulley of the RD just slightly ahead the noise stops - what would that indicate?
    tlg
    tlg is offline
    May 2011
    What size cassette and which derailleur are you using?
    Mar 2019
    Its a brand new bike with a 9 speed cassette and SORA RD.
    Some pictures : https://imgur.com/a/k9ljNbY
    Sep 2011
    That video shows the side of the drivetrain we don't need to see. I would make sure the chain is routed through the pulley arm correctly. There's a tab between the pulleys. It sounds to me like the chain is on the wrong side of that tab, causing it to rub on said tab and make that awful noise. A quick video, or photo of the other side of the derailleur would help determine what is going on better.
    'brifter' is f'ing stupid
    That would indicate that your derailleur won't adjust properly for the cassette and length of chain you are using. In your video you have the chain on one of the middle cogs, is the noise worse on the larger/largest cogs? If so you are probably using a cassette that is over the capacity of the derailleur.
    Tell me about ALL of the drivetrain parts on the bike: cassette size, rear derailleur model/cage size, and what kind of crank you have (how many chain rings and size).
    #promechaniclife
    Oct 2013
    And post a picture on the chain side, in the small/small.
    BANNED
    Sep 2011
    I just looked at the imgur link. Everything looks normal to me (obviously, pictures don't move or make sound). OP says it "shifts fine". All I can figure from what I've seen and heard here is that he's just off by a half a barrel adjuster turn.
    OP, while turning the cranks, fine tune the barrel adjuster very slowly counter clockwise and listen for that noise to stop. If it gets worse, slowly turn it the other way. If that doesn't do the trick, I would have the hanger alignment checked.
    Oct 2017
    if the noise gets better by pushing in (or out)on the lower jockey wheel, I suspect you might have a bent rear derailleur hangar.
    Your bike shop should have a tool to check this. It's a 10 minute job to check and adjust this.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Finx View Post
    This is what I am thinking.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    After seeing the photos it's pretty obvious you're right, the hanger is definitely bent in.
    #promechaniclife
    Mar 2019
    The gear shifting is fine. I can only hear the rumble when the chain is on the bigger crank in the front and on the 4-5 gear (smaller cogs from the top) in the rear.
    Here is a video of the sound. https://www.youtube.com/watch?v=lyataluRBu4
    You can hear the additonal rumble to the chain clatter.
    Mar 2019
    Its by pushing the jockey wheel forward towards the crankset, and not inwards towards the wheel.
    Also if I turn the bike upside down, the noise minimizes *shrug*
    Sep 2011
    The videos you are posting are really not helping. You need to film from behind the rear derailleur.
    Mar 2019
    Quote Originally Posted by 202cycle View Post
    https://www.youtube.com/watch?v=eUjGklfmJ10
    If the noise is coming from the rear end show the damned rear end. From behind.
    #promechaniclife
    Sep 2011
    I recommend taking your bike to a shop.
    Banned Sock Puppet
    May 2014
    The video you just posted is in front of the crankset. Put the camera BEHIND the bike BEHIND the rear derailleur. We need to see the pulleys in motion from the rear.
    "With
    -- DCGriz, RBR.
    Mar 2019
    all right guys here are two videos
    First from the back : https://www.youtube.com/watch?v=QN-A...zdeOyUEECyovJo
    Second - i placed my phone right next to the BB : https://www.youtube.com/watch?v=oTHl...p2L4-dx44tWr7Q
    Sep 2011
    I am unsubscribing form this thread. Take your bike to the shop. You obviously don't know what BEHIND the derailleur means. The first of those videos was almost exactly the same as the previous video you posted. The second video shows your thumb I guess.
    Mar 2019
    The second video is just me trying to get as close as possible to BB to record the sound.
    If you think I am trying to avoid LBS i am not - there just isnt one nearby. The closest is 3 hrs drive.
    Here is behind the deraillur : https://youtu.be/4_CYuNMF2sA
  1. Help me figure out whats wrong!!
    By pulser955 in forum Coaching
    Last Post: 04-30-2013, 12:58 PM
  2. New chain making huge racket, no stiff link though...ideas?
    By sqwk77 in forum Components, Wrenching
    Last Post: 01-14-2012, 08:33 AM
  3. Cadbury Creme Eggs are a racket
    By BAi9302010 in forum The Lounge
    Last Post: 03-13-2011, 04:08 AM
  4. Neuvation F100 making a racket over bumps
    By bateswil in forum General Cycling Discussion
    Last Post: 05-15-2010, 07:34 PM
  5. Calling Ed Racket - eurovids from the new season?
    By aljames in forum Cyclocross
    Last Post: 09-25-2007, 03:23 AM
