Carbon Fork and Spacers
Results 1 to 15 of 15
    Nov 2014
    Sorry to dredge this topic again, but I wonder where people are at with this.
    When I purchased my endurance format CF bicycle I found that to replicate my position, I needed to slam the stem down to the headset top cap. The 200mm head tube dictated this and yes I should have just purchased a traditional racing road bike. Trouble is, Bianchi issued a maintenance warning and for safety urge users to use a minimum of 5cm spacers below the stem and a maximum of 5cm above the stem. Other manufacturers have very similar warnings.
    Yes, I am only approximately 5cm higher than I would like and trigonometrically a little closer to the bars, but I sure wish I could get lower, especially when on the hoods.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by GKSki View Post
    5cm (1.97") Do you mean 5mm?
    So is there a question in your post? Are you looking for solutions? What angle stem are you using?
    Nov 2014
    Yes, 5mm spacers. Sorry. Just wondering if people have heard differently regarding manufacturer requirements, above and below.
    'brifter' is f'ing stupid
    5mm? Just ride it.
    #promechaniclife
    Move the hoods (aka the whole shifter) or rotate the bars to accomplish the same thing then if you're seriously that sensitive to 5mm hoods height.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    How many degrees is your stem? Would it be too much change to flip it?
    Jay's solution seems like the quickest and easiest.
    "With
    -- DCGriz, RBR.
    Oct 2013
    I just slammed my stem on my new endurace bike, full stack of spacers above. Jesus will watch over me....
    BANNED
    Nov 2014
    I believe it is a standard 6d FSA SL/K stem, so 84 or 96 degrees. Using it at 84 and flipping it would set me up even higher, not lower.
    Nov 2014
    I believe the reason for Bianchi specifying at least 5mm under the stem and a maximum of 5mm above the stem has to do with the minimalist FSA compression plug that they use. At least that would be the reason for the 5mm above, so that the top cap screw can reach the compression plug well enough to place the latter centered in the stem clamp area.
    Banned Sock Puppet
    May 2014
    Oh OK, I wasn't sure which way you had it flipped.
    "With
    -- DCGriz, RBR.
    I love to climb!
    Reputation: Jwiffle's Avatar
    Mar 2005
    Put a -17 stem on.
    Stop in at Element Sports. www.elementsport.com
    Get Out! Have Fun!
    Oct 2013
    Or... change the plug!
    BANNED
    Nov 2014
    That would be the right thing to do so that the stem could be slammed and still the top cap bolt could correctly position the plug. However, that would still void the warranty, etc. because Bianchi published the service notice requiring at least 5mm under the stem.
    Nov 2014
    When I first had the bike fitted, I had the stem slammed to the headset top cap (with the exception of a 3mm metal washer that I took to be a part of the headset). I knew I was getting an endurance bike, but with this setup, I was very, very close to the position I had on the racing frame it replaced (warranty replacement).
    So, I was happy with my racing position on this endurance frame until then the manufacturer came along with a safety notice document stating that I am required to use at a minimum a 5mm spacer below the stem as well as a 5mm spacer above the stem.
    https://www.bianchi.com/wp-content/u...uction_Eng.pdf
    Oct 2013
    If you want your warrenty.... use a 17deg stem installed with the horizon, it's a good look!
    BANNED
  1. Are Marks (indent) on carbon fork from spacers normal?
    By sheepherder in forum General Cycling Discussion
    Last Post: 08-23-2019, 08:07 AM
  2. How many spacers to discard ? ( and fork cut)
    By Devastazione in forum Components, Wrenching
    Last Post: 09-15-2014, 08:25 AM
  3. Replies: 2
    Last Post: 05-09-2012, 03:48 PM
  4. Easton EC90 SLX Fork and spacers
    By Thorn Bait in forum Bikes, Frames and Forks
    Last Post: 12-17-2004, 05:58 AM
  5. Carbon Fork and Spacers
    By jjspike in forum Bikes, Frames and Forks
    Last Post: 10-07-2004, 12:35 PM
