Carbon vs. Alloy Stems and Seatposts
Results 1 to 8 of 8
    Jun 2007
    I am building up a bike and looking at different stems and seatposts. My present bike has both a carbon seatpost and a carbon stem, both by ControlTech. I have had no issues with either. Are the carbon stems and seatposts better than the ones made of aluminium or scandium?
    Carbon Fiber = Explode!
    Reputation: CleavesF's Avatar
    Dec 2007
    yes because they EXPLODE!
    '09 Voodoo Wazoo
    '08 Pedal Force RS2
    '06 Raleigh Cadent 5.0
    '01 Trek 4300 MTB
    '93 Norco Nitro MTB Touring
    '88 Schwinn Prelude Fixie
    1 hour of running = 1 hour of wasted time when you could have been riding. - Alaska Mike
    duh...
    Jan 2005
    Quote Originally Posted by 123prs
    define "better"
    Jun 2008
    Quote Originally Posted by CleavesF
    I am envisioning a terrorist with a bunch of stems strapped to his chest.
    I really do not believe carbon is any better in this dept--- but I am a bit all over the map. I have an all carbon bike and two steel road bikes with AL stems, posts, bars. Carbon looks cool, and is a bit lighter, but functionally there is no real difference. The real issue to consider with the seatpost is how easy the clamp is to adjust..
    favorites...
    Carbon makes little sense for a stem, unless you MUST have the carbon look. Most carbon stems are no lighter and many are heavier than the best aluminum models. They usually cost 2-3 times more.
    As for post, I've been using carbon for the last 8 years with no problems, but I insist on a model that has a 2-bolt clamp to permit fine angle adjustments. I've had good luck the FSA K-force light, that is available in 0, 25 and 32mm setbacks. The ITM Millenium/Selcof 2-bolt post also work well.
    Anti-Hero
    Reputation: Andrea138's Avatar
    Mar 2008
    I don't really think there's anything wrong with carbon other than the price, but I think that Thompson stems & seatposts rock.
    No turkey unless it's a club sandwich
    Brickhouse Blog
    I've bounced back and forth between aluminum and carbon stems on my new bike. I have a couple with my stash. Not much difference. I got an aluminum stem to replace the carbon one that came with my bike (it was too long). The aluminum stem is lighter by ten grams, or something like that (which is nothing). I do use a carbon seatpost with my carbon bike, and it's a one bolt, I can get it dialed in where I want it. I have an aluminum seatpost on my old steel bike. Carbon has a nice look. I like to look down and see that zoot carbon stem, but the aluminum one works very well. Some of the prices for the carbon stems and seatposts are outrageous, when an aluminum one will work just as well.
    If you want a nice looking aluminum stem or seatpost, look into a Ritchey WCS 4-Axis wetblack..
