Cassette gearing for high speed flat riding
Results 1 to 25 of 30
    Jul 2010
    Hey guys, I just ordered a new bike (17' giant propel) which comes with Shimano Ultegra 11x28 and wondering if that would be ideal for riding at 26-31mph on the flats with zero climbing (south Florida a1a)
    A buddy of mine recently got a 17' dogma f8 with an ultra cassette as well however his gears appear to be a bit smaller and have less of a jump in size going gear to gear however his gearing is unknown.
    thanks!
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    11-21, if it's 11 speed I believe 11-23 is as corn cob as it gets.
    Jul 2010
    Quote Originally Posted by hfc View Post
    Awesome, thanks! 11x23 it is.
    Jul 2010
    while am at it, would you replace the 36/52 crank with more teeth? 53/39?
    Pathlete and Pedalphile
    Reputation: redondoaveb's Avatar
    Jan 2011
    Quote Originally Posted by illlili View Post
    A 52/11 @ 100 rpm is going to get you 37 mph, I don't think you're going to need the 53
    If you try to fail, and succeed, which have you done?
    Russian Troll Farmer
    Sep 2016
    Quote Originally Posted by redondoaveb View Post
    .....and if you do, I will declare you "hors catagorie', and enter you into next year's TdF....
    "L'enfer, c'est les autres"
    'brifter' is a lame word.
    If you're going that fast why bother changing the cassette? You'll be in the 11/12/13/14 either way. You're wasting money.
    I work for some bike racers
    and a bunch of skateboards
    Jan 2011
    Yeah, you can get a four cog cassette, think how much weight you'll save.
    Banned forever.....or not
    Aug 2002
    11-23 and block out the 11, 12, and 13.....A 14x52 will take you into the low 30's.
    Dogbert.
    I>U
    Oct 2013
    Oh no he can't, he can't live without his 16~
    BANNED
    Jan 2011
    You know I'm the only one with a 16.
    Oct 2013
    Well we were talking cassettes today up the mountain, so I did a little research when I got home & dang if I don't have a 16 on my 11-32. But I never know when I'm in it, but it is only for 5% of the time I am sure!~
    I think I was in the 28 75% of the time going up & the 12 most the way down, which would be about 25% of the time.
    But my Seven don't have one, I know that for a fact!
    BANNED
    Reputation: Fredrico's Avatar
    Jun 2002
    Sure, use the 15, 16, 17 for tempo riding; keep the 20, 23, 26, 28, for the highway overpasses.
    Reputation: velodog's Avatar
    Sep 2007
    You could build one of these on a modern cassette using the appropriate 11 tooth gear.
    17t x 17t cogset
    Too old to ride plastic
    coaster
    Reputation: Lelandjt's Avatar
    Sep 2008
    If I were you I'd replace the crank with 39/53 and the cassette with 11-23. Actually that's the gearing I have on my bike and the only gearing I've ever had since getting into road bikes in '96. I won the Mt. Washington hill climb on that gearing so it'll get you over a few overpasses.
    The point of it though is to have small steps between gears, the larger chainring lets you use a larger cog in back for less friction and longer wear, and the tall gears let you slow down your cadence and rest.
    Apr 2014
    Is there wind? However I do not know what kind of cassette you should get other then whatever is the most corn cob available. .
    I would probably just get a fixie. Maybe the Specialized Langster for $600.00.
    So here we have someone who rides around at 26-31 MPH getting advice from a guy who won Mt. Washington with 39x23 as the easiest gear.
    Gotta love the internet.
    a real member's member
    Jul 2016
    '17 ... 2017
    17' ... 17 ft
    Jul 2010
    Jul 2010
    thanks for all the replies guys. got both a new crank and cassette on the way. https://youtu.be/ZCX-cuWJobE gotta love flat south Florida a1a riding.
    Oct 2013
    Quote Originally Posted by blackfrancois View Post
    '17 ... 2017
    17' ... 17 ft
    I just thought he was pretty tall.
    BANNED
    Tig
    Tig is offline
    Clear Lake, TX
    Reputation: Tig's Avatar
    Quote Originally Posted by Fredrico View Post
    ^ So much this.
    Feb 2006
    11-23: 11-12-13-14-15-16-17-18-19-21-23
    11-25: 11-12-13-14-15-16-17-19-21-23-25 -- This drops the 18 and adds the 25.
    Here's Mike Sherman's Gear calculator with the 11-23 and 36-52 settings. You can bookmark the URL to recall those settings later.
    The charts update on the fly as you change cadences or gearing.
    Your current 11-28 cassette at high racing cadences:
    And the 11-23 at the same cadences:
    With the 18 and 16 cogs added, you get better, closer shifts in the 20-25 mph range. Your current cassette already has the 11,12,13,14,15, same as the 11-23, so your 25-30 mph cadences won't change.
    Yes,
    That video link was impressive, a lot of 25-30mph riding. But you'll have windy days or slower speeds and will still use the rest of the cassette.
    Jun 2002
    Quote Originally Posted by rm -rf View Post
    Yes,
    Above chart illustrates it well. The top red steps has a gap between the 17 and 15 and the 17 and 19, that gets filled in by the 16 and 18 on the 11-23 cluster. These gears are in the range 15-20 mph, the speeds rider will be going most of the time "tempo-ing" on the flats, training the aerobic system below AT. I wouldn't want to give them up.
    The 28 wouldn't get used much. All grades could be handled in the 21 or 23 at typical climbing cadences, which would be around 60-70 rpm at typical climbing speeds, 6-12 mph. Rider could probably spin up those overpasses at 90 rpm in the 23, going 11-12 mph, easy.
    coaster
    Sep 2008
    P.S. Junior class. Tyler Hamilton won the overall that year. I think he had the same gearing.
  1. What cassette are you riding on flat roads?
    By Mark 1 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 05-31-2012, 07:14 PM
  2. Gearing for flat Florida
    By gaspi101 in forum Components, Wrenching
    Last Post: 08-02-2011, 05:33 AM
  3. Best Gearing combination "cassette" for flat ground
    By spinnertsaf in forum Components, Wrenching
    Last Post: 12-09-2010, 04:44 PM
  4. Is this gearing too high for street riding?
    By Dave Hickey in forum Fixed/Single Speed
    Last Post: 12-15-2008, 02:49 PM
  5. Gearing - low and high
    By lawrence in forum General Cycling Discussion
    Last Post: 07-03-2005, 03:34 PM
