cassettes, derailleurs, shifters, cranks
Results 1 to 5 of 5
    Nov 2008
    Red face cassettes, derailleurs, shifters, cranks
    my current setup is:
    sora shifters...going to upgrade to ultegra ST-6603 triple/10-speed shifters
    stock triple crank
    stock triple FD
    dura-ace 7800 9/10 speed compatible RD
    stock 9-speed cassette...going to upgrade to ultegra CS-6600 10-speed cassette
    question is, can i use my stock crank and FD w/ the planned upgrade? i'm going to upgrade the FD and crank eventually but it's on the back burner for now.
    thanks, folks.
    should work
    Quote Originally Posted by george costanza
    stock triple crank
    stock triple FD
    thanks, folks.
    I don't see any reason why it would not work.
    Reputation: Ziggy's Avatar
    Sep 2006
    Is the chain any thinner with the 10 spd setup... might have to change the chain rings but I don't know for sure.
    Nov 2008
    Quote Originally Posted by Ziggy
    oh, that makes a lot of sense. my buddy just told me that i'll need a new chain going from a 9 to a 10 speed because the spacing is a bit different.
    as for the FD, is there a difference as far as trim adjustments w/ a 9 and 10 speed?
    Jun 2005
    10 speed FD's have a narrower cage for the thinner chain.
    That being said I ran 10 speed with a 9 speed FD without any trouble (ultegra double)
    Best to try it & see if you are satisfied with the shifting performance
