Centaur UT or new Athena UT Chainset ?
Results 1 to 11 of 11
    Reputation: bolo yeung's Avatar
    Jul 2008
    Im after a new campagnolo alloy UT chainset. I can get either of the above for around the same price. Will be for use on a 10 speed Chorus equipped bike. I've already swapped over a Record 10 spd alloy chainset to Centaur UT on an old bike and was thinking of doing the same on another.
    QUESTION: the chainrings on the Centaur UT Alloy are pressed instead of machined (if you look closely at the teeth, the quality of finish is not quite as good as the old chainrings on the square taper centuar crankset that were machined rather than pressed alloy).\
    Am I correct that the chainrings on 11spd Athena UT alloy chainsets are also machined. I haven't seen them close up, only on internet pics (NB: as I'll be using it with a 10spd chain I'll put some of the 0.4mm washers between rings and crank to space rings out a little).
    Good bicycles turn effort into emotion.
    They provide the means to reach, and sometimes exceed, your potential.
    On a fine bike you can ride better than you ever thought possible and catch glimpses of extraordinary athletic prowess you didn’t realize you had.
    The experience is inspirational and addictive.
    You long to sustain it.
    ~ jim langley
    Jan 2010
    My Athena UT, now a couple of years old, have machined rings.
    No need to respace them. A 10 speed chain will run fine.
    There's sometimes a buggy.
    One.
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    This is the main reason to get Athena over Centaur. The shifting is noticeably better.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Jan 2010
    Just reread the OP. You do know that "new" Athena is PT right?
    And my UT Athena crankset is the carbon version, so I'm not sure that the alloy version had the same rings.
    One.
    Jul 2008
    Thanks for making that point. The Athena chainset I'm looking at 'is' the compact 'UT' alloy model.
    ~ jim langley
    Jan 2010
    Just to add to the fun, I also have an early Centaur UT crankset (2007), that has the machined rings. They cheeped out later.
    One.
    Feb 2006
    Quote Originally Posted by bikerjulio View Post
    Ditto. In 2008 I scored a 2007 Centaur UT from Nashbar for $20 cheaper than the 2008stamped ring version from any of our wholesale suppliers (yes, I work in the bike biz.)
    Very lucky as there is a big difference.
    Anyone who believes there are no stupid questions never worked in a bike shop.
    Jul 2008
    The sad thing is, I'm buying this to replace another worn out alloy record crank and chain rings :'(
    I've said it in other posts but I'm convinced the outboard bearing/UT system is a more efficient means of transferring power than the square taper/cartridge bb system. But thats just my opinion ;)
    ~ jim langley
    Matnlely Dregaend
    Jul 2006
    I bought two Centaur square tapered carbon cranks with machined EPS rings (compact and regular) when Nashbar was almost giving them away for $79 each. It was cheaper to buy the cranks than the rings alone!
    AC0
    AC0 is offline
    Aug 2010
    [QUOTE=bikerjulio;4217047
    And my UT Athena crankset is the carbon version, so I'm not sure that the alloy version had the same rings.[/QUOTE]
    I have an Alloy UT Athena (compact) crank and the rings are machined.
    AC
    classiquesklassieker
    Reputation: orange_julius's Avatar
    Jan 2003
    Quote Originally Posted by bolo yeung View Post
    I upgraded a frame from 2004-ish Record square-taper BB/crankset system to a 2008-ish Centaur UT BB/crankset system. The new system is stiffer, seems to spin more nicely, and lighter. Sounds good to me.
