Ok great, thanks. I think that I usually pay attention to that but I'll still check. One thing related to this is that when I put the hub in the dropouts there seems to be a lot of play and it requires me manually aligning the rim evenly between the brake calipers while tightening the skewer not to get brake rub. I can't just place the hub between the dropouts and tighten the skewer to the ~90 degree (by feel point) and clamp to have the rim be dead center between the brake caliper.
I checked the skewer springs tonight...both sides had the smaller diameter on the inside.
Reason: Update with more info
By eljimberino in forum Components, Wrenching
Last Post: 04-20-2012, 01:07 PM
By SlowBubba in forum Orbea
Last Post: 03-18-2008, 06:09 PM
By bent_spoke in forum Components, Wrenching
Last Post: 09-15-2006, 05:09 PM
By ruksis in forum Components, Wrenching
Last Post: 06-09-2005, 03:19 PM
By DougSloan in forum Fixed/Single Speed
Last Post: 03-15-2005, 07:35 AM
- You may not post replies
- You may not edit your posts
Forum Rules
