Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
  1. #26
    Oct 2013
    Did you get that fork with the frame from the same manuf?
    BANNED
  2. #27
    Huge in Japan
    Reputation: craiger_ny's Avatar
    Jun 2014
    A what?!? .25mm? You must mean 2.5cm.
    I had a bike with an FSA integrated headset that the top cap rubbed slightly against the head tube. Tightening it only served to bind the steering without actually properly tightening the headset. I cut a circular shim out of .010 shimstock (approx .25 mm) and placed it between the top cap and compression ring. Fixed it. Come to find out microspacers are a thing.
    If OP's headset steering binds when tightened (from the top cap contacting the headtube) and exhibits the looseness that he is describing then I'd be inclined to recommend a microspacer. If there is no binding then this is not the fix.
    Not sure if 'top cap' is proper nomenclature but I'm referring to the cap that contacts the compression ring before the spacers are put on. The microspacer goes between that cap and the compression ring.
    Interwebs bumpersticker goes here
  3. #28
    .je
    .je is online now
    Reputation: .je's Avatar
    Aug 2012
    I wonder if you could take a 1-minute video of everything being assembled, so we can see what is happening.
  4. #29
    'brifter' is a lame word.
    Quote Originally Posted by craiger_ny View Post
    I have tons of those...and didn't even think of them! Thought he was talking about regular under-the-stem spacers. They come w/ lots of Trek bikes but generally aren't needed...I save them just in case they're needed at some point.
    I work for some bike racers
    and a bunch of skateboards
  5. #30
    Reputation: nova_rider's Avatar
    Sep 2005
    "...the bottom bearing which is too stiff to get out from the Head tube"
    The lower bearing should not be this tight. If so, it may not be properly seated and can certainly cause these symptoms. Try to get it out and make sure it is installed correctly.
  1. Help with MC053 Miracle Foil Chinese Carbon Frame Seat post Clamp Wedge
    By GhostDragon in forum Bikes, Frames and Forks
    Last Post: 05-02-2016, 08:36 PM
  2. Headset for a new-ish Chinese carbon frame
    By myhui in forum Components, Wrenching
    Last Post: 01-11-2014, 03:14 PM
  3. Need help with Chinese frame sizing.
    By MassCyclist in forum Bikes, Frames and Forks
    Last Post: 12-13-2010, 12:16 PM
