Is cleat float and tension related?
Results 1 to 10 of 10
    Oct 2012
    Float is allows some feet movement after clipped in and tension affects how much strength is needed to unclip right?
    Do they mean the same thing, completely different or has some relationship? Eg If tension is set tighter, does it result in less float?
    Reputation: Ventruck's Avatar
    Mar 2009
    As in saying, lower tension allows more float because there's more "allowance" for the clip to give? No. That's more like insufficient tension period.
    Float and tension are separate things. Float is dictated by either cleat shape, or if you're using Speedplay, different set screws which are still on the cleat anyway.
    wim
    wim is offline
    Feb 2005
    Not an exact answer to your question, but there are pedals (Time, perhaps others) on which you can adjust the force required to induce rotational float. Basically, this works by adjusting the tension of the re-centering spring, which is there to nudge your foot back into the center position. This spring has nothing to do with cleat-in or cleat-out effort.
    Idiot at large
    Apr 2010
    Quote Originally Posted by nolight View Post
    On my look keo classics, they are not related.
    Cranking down on the tension, does not change the geometry of the back clip, all it does is preloads the springs for a higher spring force to overcome.
    Float is dictated by the cleat geometry relative to the pedal geometry
    2010 Specialized Secteur Elite with the RBR not-approved Mavic Ksyrium Elite wheelset
    2009 Specialized Rockhopper Comp 29er upgraded to SRAM X9 with 1x10 and Stan's Arch EX rims and tubeless.
    2013 Cannondale CAADX-6 Tiagra with 9-speed SLX RD to run 11-32T cassette and Stan's Alpha 400 rims and tubeless
    and
    Some Burton snowboard setups, one with stiff ol' Camber and one with Rocker-Camber-Rocker
    Reputation: chudak's Avatar
    Jul 2012
    Some pedals have "unsprung" float (e.g. my old Time Equipe's and my Speedplay zero's) meaning there is no resistence to the float by some kind of centering mechanism/spring. Others have "sprung" float (e.g. Time Iclics) where they allow some 'float' under the tension of the release spring but within that allowed movement you are still clipped in.
    I much prefer unsprung float, which is why I returned the Time Iclics because I mistakenly thought they would be similar to my 20 year old Equipe's.
    2013 Felt Z4 56cm
    1990 Basso Loto 56cm
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    Quote Originally Posted by wim View Post
    I don't know... the spring clearly compresses when you clip in and out, and the adjustment compresses the spring more. I never understood how the two can be unrelated when there is only one spring there to begin with.
    Edit - this is for Time RXS type pedals.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by DrSmile View Post
    You make a good point, and I don't have an explanation handy. Time consistently claims that, quote: "Binding tension is not adjustable but is pre-set." If their "sensor elasticity tuning (S.E.T)" really doesn't affect binding tension, it would have to act on the spring in such a way as not to affect binding tension. One possible way is to have the spring act in compression for one function and in torsion for the other. But you say it's compressed for both functions, so I don't know. Need a pedal in front of me, I guess.
    Reputation: looigi's Avatar
    Nov 2010
    Right. On some pedal systems, there is free float and the release spring only starts to get compressed at the point you exceed the range of free float, then you rotate more against the spring until you reach the release point.
    ... 'cuz that's how I roll.
    Oct 2012
    Thanks. So if I use yellow Shimano cleats with 6 deg float, the float is fixed unless I change cleats?
    Is red cleats with 0 deg float better for efficiency since it prevents unnecessary movement ie is it true that pros tend to use cleats with less float?
    wim
    wim is offline
    Feb 2005
    "Fixed" is a bit misleading here because it means "no float" in pedal lingo. But yes, the yellow Shimano cleat gives you a float range of 6 degrees and no more (3 degrees left + 3 degrees right.) The blue Shimano cleat gives a float range of 2 degrees. And as you said, the red cleat puts you into the fixed mode.
    It's never been shown that riding fixed is more efficient than riding with float. There are instances of a rider not tolerating float (or much of it) because of a biomechanical issue or injury, but these are rare. For most riders, the adage "float can't ever hurt, but might help" holds true, so going with some float would be my recommendation. And of course, many riders absolutely need float to stay injury-free. For them, rotation of the foot is about as far from "unnecessary motion" as you can get.
    As to the pros: some of them do use float, some of them ride fixed. But you need to consider that generally, only those who are biomechanically perfect reach the ranks of the pros. Statistically, it's not a good group to compare yourself against if you're a recreational rider.
  1. Cleat dilemma/experiment...float, no float?
    By Ventruck in forum General Cycling Discussion
    Last Post: 11-16-2010, 05:58 PM
  2. Cleat Float - What's optimal?
    By LOOKFTW in forum General Cycling Discussion
    Last Post: 06-16-2008, 04:17 PM
  3. Cleat and float question
    By msander19 in forum Components, Wrenching
    Last Post: 08-07-2007, 08:18 AM
  4. Tension and Float
    By z06ontrack in forum Components, Wrenching
    Last Post: 08-02-2006, 08:31 AM
  5. Cleat Float what's your degree?
    By Cycle_Spice in forum General Cycling Discussion
    Last Post: 07-25-2006, 07:48 PM
