Compatibility Question
Results 1 to 7 of 7
    Apr 2012
    I have a Lemond Versailles with 9 speed components, looking to change out the 53/39 crankset to a compact crank. Would a new Shimano 11 speed crank work on a 9 speed group set ?
    Thanks
    Dec 2001
    I have done that exact mod several years ago and it worked just fine. My only issue was the front derailleur. Be sure you can move it down a good amount so a clamp-on mount is needed. Good Luck!
    Apr 2012
    It is a band on front derailleur so that is not an issue , did you continue using a 9 speed chain or switch to an 11 speed ?
    Dec 2001
    I used a 9 speed chain. The difference in the chainring spacing between 9 & 11 is miniscule (sp).
    Quote Originally Posted by lhartle1 View Post
    For what it's worth I found 11 speed chains work quite a bit better than 10 with 10 speed parts (talking about rear shifting here). Not sure if the same would be true 11 chains with 9 but you might want to give it a try just for kicks.
    The downside is 11 chains don't last as long.
    Apr 2012
    Thanks for the answers guys. Changed my mind and decided to give new life to the Lemond , just ordered new Ultegra groupset .
    50/34 crank and medium cage rear derailleur , the old legs will appreciate it.
    Dec 2001
    Sounds like a much better plan...I also just upgraded last Sep to Etap 11 with 50/34. Night and day improvement. My old legs are doing much better now. Cheers!
  1. DA 10 Compatibility Question
    By stig rolex in forum Components, Wrenching
    Last Post: 01-26-2005, 10:03 AM
  2. Question about Tiagra and Deore FD Compatibility
    By jcuesico in forum Components, Wrenching
    Last Post: 08-02-2004, 03:02 PM
  3. new frame/component compatibility question
    By rightsaidfred in forum Components, Wrenching
    Last Post: 07-25-2004, 03:36 AM
  4. FSA carbon pro team crankset / campy compatibility question
    By LowCel in forum Components, Wrenching
    Last Post: 06-14-2004, 05:32 AM
  5. Shimano pedal compatibility question
    By Roger H in forum Components, Wrenching
    Last Post: 02-12-2004, 03:58 AM
