Convert Campy Power Shift to Ultra Shift?
Results 1 to 5 of 5
    Jan 2002
    I'd like a set of silver alloy 11 speed levers and Athena is as high in the line as you can go and get that. Unfortunately, the Power Shift mechanism is the only way it's available. (Previous year Athena shifters with Ultra Shift weren't available in silver)
    Just to be clear here, the Power Shift mechanism only allows single gear jumps down the cassette, whereas the Ultra Shift (Chorus and above) gives you the ability to 'dump' the chain down up to 5 cogs if desired.
    Is it possible to send a Power Shift lever into a Campy Service Center or Dealer and have it upgraded to Ultra Shift? Much like you'd have a lever rebuilt?
    If so, where? cost?
    Many thanks.
    Reputation: Ventruck's Avatar
    Mar 2009
    http://forums.roadbikereview.com/cam...ft-240344.html
    from that thread, sounds like a no.
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    You could always take the Athena aluminum brake lever off the shifter body and mount it on a Chorus body. I'm willing to bet that they didn't change that part, since they still produce the carbon lever version of Athena which started as Ultrashift. Stick the Chorus carbon brake levers on the Powershift body and sell it to someone at enough of a discount that they won't care.
    classiquesklassieker
    Reputation: orange_julius's Avatar
    Jan 2003
    Quote Originally Posted by JLane View Post
    If so, where? cost?
    Many thanks.
    Not possible. Look at the spare parts list:
    http://www.campagnolo.com/repository...RT_A-11-11.pdf
    SR, Record, Chorus are pretty much identical in terms of mechanical parts, only difference is in materials.
    Athena parts look very different. And most important is that the plastic body is different from SR/R/C.
    The levers all look to have the same shapes and dimensions and mountings, across the entire Campag range.
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    Quote Originally Posted by Kontact View Post
    This definitely sounds like the winning solution!
    "Luminous beings are we...not this crude matter!"
  1. Replies: 12
    Last Post: 07-13-2011, 12:47 AM
  2. I am done with Ultra Shift
    By darkmother in forum Campagnolo
    Last Post: 10-02-2010, 01:04 PM
  3. Centaur Ultra-Shift
    By DanTourino in forum Hot Deals
    Last Post: 09-07-2010, 02:12 PM
  4. Replies: 8
    Last Post: 12-02-2009, 06:26 AM
  5. Campy Ultra Shift levers used w/QS frnt derailleur
    By canamdad in forum Components, Wrenching
    Last Post: 07-24-2009, 12:27 PM
