Converting a rear wheel from 10-speed Campag to 9-speed Shimano?
Results 1 to 9 of 9
    Sep 2007
    Can it be done without getting a whole new hub?
    Banned forever.....or not
    Aug 2002
    More info
    Campy prebuilt wheel?
    Campy hub(model) and rim?
    8 speed, 9/10 speed?
    Dogbert.
    I>U
    Sep 2007
    Quote Originally Posted by MR_GRUMPY
    More info
    The wheels are 2006 Bontrager XXX Race Lite carbon tubulars, currently set up for 10-speed Campag. Seller says "can easily be switched to accommodate Shimano", I'll pursue this further with seller, but also want to get a reality check from others if possible.
    I've seen that you can buy a spacer kit to convert a 9-speed Campag cassette to 9-speed Shimano spacing, but ideally I'd like not to have to buy a new cassette.
    Aug 2002
    Yes.....easily done. You need a Shimano type freehub body plus some minor parts. Best done by a "competent" bike shop.
    Let them order all the needed parts.
    Dogbert.
    I>U
    Oct 2007
    I don't know if this helps but I bought a set of 2005 Campy Eurus wheels set up for Campy that my LBS put together a 9-sp Shimano-spaced cassette for me (not Shimano-made mind you). I think they basically rigged up spacers to make it fit. But they did say that I probably won't be able to move to 10-sp so I've been thinking about whether to sell these wheels and get a set that will allow me to upgrade. I love these wheels though so it's a tough decision.
    Sep 2007
    Thank you! I'll phone my LBS and get a quote.
    Feb 2006
    Quote Originally Posted by pretender
    I hope your LBS is a Trek dealer. Those Bontrager wheels have a DT Swiss hub and Trek stocks the freehub bodies in Shimano and Campy. The tricky part is getting the right one as there were some running changes with the Bontrager wheels.
    Jun 2003
    Quote Originally Posted by Richard
    +1
    You'll need the serial number from the hub.
    Big is relative
    Reputation: bigbill's Avatar
    Feb 2005
    Quote Originally Posted by shinsplints
    Campy sells a shimaNo freehub for their factory wheels. It is ten speed only so you can and will have to switch. It is an easy swap.
    Retired sailor
