Couple FD questions from an idiot
Results 1 to 4 of 4
    Il faut d'abord, durer.
    I guess the 9 speed FD is a little narrower, but would an Ultegra triple front der. shift a Sora drivetrain without any problems?
    Also if you went to a 28/38/48 crank on the road bike, would you stick with a road derailleur or a MTB derailleur up front?
    My plan is to ask a lot of stupid questions for a while, then after I've learned everything, I will come back under a different name and answer newbie questions like an expert.
    Thanks so much.
    Fd
    Quote Originally Posted by Gargamel
    Thanks so much.
    Cage width matters a little more with triples,but usually is not a deal killer. The Ultegra works with that chainring setup. I used a 9 speed 105 triple front with a 46/36/26 in an otherwise 7 speed RSX STI setup using a sram 8 speed chain with no issues.
    Diesel Engine
    Reputation: Mike Prince's Avatar
    It shouldn't matter as long as it is a triple derailleur.
    Jun 2003
    Derailleur
    If you have road shifters you'll need a road derailleur and lower it to where it clears the big ring by 1 or 2 mm.
    Al
  1. New to road cycling, frame questions
    By rotary16 in forum General Cycling Discussion
    Last Post: 04-19-2004, 11:10 AM
  2. some easy questions on racing
    By Andy C in forum Racing, Training, Nutrition, Triathlons
    Last Post: 04-18-2004, 02:36 PM
  3. some easy questions
    By Andy C in forum General Cycling Discussion
    Last Post: 04-18-2004, 11:04 AM
  4. very exciting stem length questions
    By munga22 in forum General Cycling Discussion
    Last Post: 04-04-2004, 02:23 PM
  5. Some new questions may be asked of the good Senator
    By Live Steam in forum The Lounge
    Last Post: 03-05-2004, 11:37 AM
