Cracked seat post
Results 1 to 11 of 11
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    Cracked seat post
    First time for everything I guess. I noticed this today while washing my cross bike after a muddy gravel ride this AM. Otherwise I haven't noticed any problems. I have had what I assumed was a bottom bracket creak on steep climbs recently, considered seat post or saddle creak, but it persisted when I climb out of the saddle.
    Here's a pic:
    If I had to guess when is happened it was ride before today's when I went down a gravel road descent that was more appropriate for a mtb. I don't remember any huge bumps but the bike and I got rattled around quite a bit.
    Anyway, I'm curious if opinion is normal failure or not. It is on a cross bike, but I don't ride it that much anymore, probably less than 500 miles in the last 2-3 years and out of my 9 bikes I would have picked this seat post as the highest quality. Also would anyone drill out the bottom of the crack and keep riding it?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    That post should have a 3 year warranty on it. Thompson AFAIK is a pretty stand up company.
    hfc
    hfc is offline
    Jan 2003
    While I mentioned mileage over the past 2-3 years, alas, the bike and post are much older than that.
    Apr 2011
    Quote Originally Posted by hfc View Post
    I would never do that.
    Aluminum seatposts are relatively cheap. Get a new one.
    Short of driving the roof racked bike into the garage and stuff like that there's no such thing as a 'normal' seatpost failure.
    No, I wouldn't drill it keep using it.
    Mar 2013
    Quote Originally Posted by bvber View Post
    +1 on this. Just get a new one OP, it's not worth the risk.
    hfc
    hfc is offline
    Jan 2003
    Thanks all. Already bought a new one, just curious about the drilling. I would think that it wouldn't fail spectacularly like a fork steerer or stem. Probably would just continue to split and then the post would slide down into the seat tube. Then again maybe the top would blow off and fling off saddle and rider.
    Big is relative
    Reputation: bigbill's Avatar
    Feb 2005
    Did you buy another Elite? I'd be wary of that model on a gravel/cross bike. Is saving weight a factor on your cross bike? The standard Thomson is really beefy and relatively light.
    Retired sailor
    Quote Originally Posted by bigbill View Post
    I'm pretty sure the Elite is the standard Thompson post and the weight weenie one is called Masterpiece.
    Dec 2006
    Google "Thomson Seatpost Crack" or "Failure".
    While it's not epidemic, it seems to have a past. The only reason I went the Google route is I seemed to recall reading on the forums a while ago about Thomson seatpost failure.
    Cozybeehive has an interesting thread on the subject.
    hfc
    hfc is offline
    Jan 2003
    @BigBill - The Elite is the standard, and the Master is the lighter one with thinned walls. I got an Oval Concepts post, primarily to get some setback, as the saddle was all the way back on the Thomson (maybe a factor in the crack?).
    @Peter, thanks for that link, interesting read.
  1. Advanced/Cracked Seat Tube
    By Aindreas in forum Giant
    Last Post: 10-22-2012, 09:14 AM
  2. Advice/Ideas on cracked seat post tube
    By jtrigowski in forum Components, Wrenching
    Last Post: 04-08-2012, 08:46 AM
  3. Replies: 1
    Last Post: 07-18-2010, 02:48 PM
  4. MX-leader seat lug cracked
    By 19lexicon78 in forum Merckx
    Last Post: 10-08-2009, 06:09 AM
  5. cracked steel seat tube
    By jerryc in forum Bikes, Frames and Forks
    Last Post: 05-17-2007, 03:15 PM
