Crank length question
Results 1 to 2 of 2
    Apr 2004
    Hello, my first post here at this forum.
    I currently have Surly Cross-check, which I mostly use for commuting. Actually, never tried cyclocross (although would like to check it out this summer). I've mostly mt biked in the past. Anyway, I'm thinking about getting a new road bike here may be sometime soon, and just started thinking about the type of components I want to get. Since I haven't had a "real" road bike, I'm not sure about certain components - one being crank length. My Surly has 172.5 ultegra cranks, which feels good to me but want to try something shorter. Is there any advantage of going shorter (170) or perhaps even longer (175)? Is this mostly a personal preference, or is there a real good reason why some people prefer one length for one condition/bike vs another? TIA and look forward to learning a lot more about road bikes through this forum in the future.
    Jul 2002
    Quote Originally Posted by MaD-X
    With shorter cranks, you can pedal through corners and have more clearance between the pedal and the road.
    If you know that you prefer to "spin" easier gears at fast rpm's, shorter cranks are an advantage.
    If you do a lot of mountain climbing, longer cranks will give you more leverage.
    Remember to raise or lower your seatpost to accomodate the change in crank length. Shorter crank means raise your seatpost. Longer cranks means lower your seatpost.
  1. change in crank length causes bouncing?
    By DougSloan in forum Fixed/Single Speed
    Last Post: 03-28-2004, 07:35 PM
  2. Wheel builders: a spoke length question...
    By 9-speed in forum General Cycling Discussion
    Last Post: 03-24-2004, 03:35 PM
  3. Sizing follow-up question: stand over vs. tt/ht length
    By TNSquared in forum General Cycling Discussion
    Last Post: 03-22-2004, 07:43 PM
  4. Just another question of crank size...
    By rocklax in forum General Cycling Discussion
    Last Post: 03-21-2004, 07:13 AM
  5. Correct BB length for LX crank on Kona Jake frame?
    By sanrensho in forum Cyclocross
    Last Post: 03-10-2004, 01:33 PM
