creek in the bottom bracket
Results 1 to 5 of 5
    Reputation: saccycling's Avatar
    Sep 2004
    I got a new Giant ocr Elite bike last month. A couple of weeks ago I noticed a creek in the bottom bracket when I put a lot of pressure on the crank. Being new a cycling, I waited a couple of weeks before I decided to call LBS. They told me it shouldn't creek and I brought the bike in and they pulled out the bottom bracket and re-greased it. It fixed the problem. My question is, is there a possibility that I might of damaged the bottom bracket ? My LBS assured me that I haven't nothing to worry about. I'm just looking for some opinions.
    Kant phuckin sphell
    Reputation: the bull's Avatar
    Jan 2003
    No
    Should be fine now.
    Dont worry.
    www.tomsgarageapex.com
    Honda Acura Service and Repair
    Sep 2004
    If you had trashed it, you likely would have noticed some problems with the crank by now. Honest! A quick lube by the LBS would not have made much difference if there were permanent damage to the BB, which by the way is a pretty stout piece of hardware. It is used to being under TREMENDOUS torque, so a little while of squeaking probably didn't bother it in the least.
    Most creaking is due to under-lubrication. The LBS appears to have corrected the problem. If your pedals turn correctly and don't grind, skip, or make other untoward noises, I'd say worry more about how you're going to pay for that fancy new bike than any problem with the bottom bracket.
    Relax, ride your GREAT new bike to death, and enjoy the road bike world. It's an awesome place!
    Feb 2002
    Check for beavers
    If there really was a creek in your BB, I would check for massive amounts of water, lots of sand and gravel, perhaps muddy creek banks, and maybe a beaver dam.
    Reputation: bahueh's Avatar
    May 2004
    similar problems with Al frames...
    i had a similar problem on my al. frame a few weeks ago, but the BB was fine.
    LBS said the noise often is created by the frame and if the BB didn't let the cranks "shimmy" or grind in any way, the BB was fine. I ended up replacing the cranks and BB for other reasons (CF goodness), and the noise hasn't come back.
    seems they fixed it...trust the LBS.
  1. American Classic Split rinb ISIS bottom bracket.
    By Juanmoretime in forum Components, Wrenching
    Last Post: 06-18-2005, 02:44 AM
  2. Help with stuck bottom bracket
    By mfuchs in forum General Cycling Discussion
    Last Post: 05-19-2004, 04:30 PM
  3. Creaky bottom bracket? Loctite? Plumbers tape?
    By mtbcyclist in forum Components, Wrenching
    Last Post: 04-21-2004, 05:22 AM
  4. Fitting FSA ti bottom bracket - problems?
    By Gilo in forum Components, Wrenching
    Last Post: 04-06-2004, 07:26 PM
  5. Big bottom bracket problem...
    By rocklax in forum Components, Wrenching
    Last Post: 03-19-2004, 11:36 AM
