Cup and Cone hub, locked but adjustable?
Results 1 to 6 of 6
    Oct 2005
    Trying to service a front wheel hub on an older Shimano wheel/hub. The lock nut is locked against the cone, but the whole lot (cone + lock nut) can be turned in/out by hand.
    Is this right ... I'm presuming that the quick release lock it in place?
    'brifter' is a lame word.
    Do you actually have cone wrenches?
    I work for some bike racers
    and a bunch of skateboards
    Oct 2005
    Yes, and there you go. I *presumed* that the cones were locked tight as I couldn't budge them by hand. But once I got out the wrenches, the lock nuts were indeed loose.
    Thanks.
    Sep 2011
    That sounds odd. Typically if the lock nut (it's called that for a reason) is tight to the cone, neither will turn on the axle, they are essentially locked in place. This is a job that you HAVE to do right, if not, you'll trash the hub in a handful of rides.
    Oct 2005
    Yes, see above. I thought they were locked, but weren't. My (novice) mistake.
    Sep 2011
    Quote Originally Posted by bing181 View Post
    I was typing mine up at the same time. Good luck with the hub service, and make sure you keep an eye on it for the first few rides. If it comes loose, you'll make a mess of it in a hurry.
  1. How often do you service Shimano cup and cone hubs?
    By ToiletSiphon in forum Wheels and Tires
    Last Post: 12-03-2016, 03:18 PM
  2. cup and cone versus sealed cartridge?
    By aclinjury in forum Wheels and Tires
    Last Post: 06-29-2012, 05:43 PM
  3. Campagnolo hub servicing - cone & cup question
    By li.steven in forum Components, Wrenching
    Last Post: 01-06-2007, 09:31 AM
  4. Question: cup and cone bearings - durability?
    By Maverick in forum Wheels and Tires
    Last Post: 12-25-2006, 02:06 PM
  5. Hub choices (sealed cartridge vs. cup and cone)
    By SJBiker in forum Components, Wrenching
    Last Post: 07-05-2006, 08:18 PM
