Cutting down steel steerer with park sg8 sawguide
Results 1 to 8 of 8
    Mar 2012
    Can I use the park sg8 saw guide with the regular 30tpi blade to cut down a steel steerer? Or is it too wide
    I think the sg8 is for the carbon blade and may be a little wider then the regular blade. I also want to make sure the regular blade is the one I use
    Thanks
    Russian Troll Farmer
    Sep 2016
    When it comes to post cutting, I've always used my plumber's tube cutter for seatposts. I'd assume it would work as well with steerers.
    "L'enfer, c'est les autres"
    Reputation: Srode's Avatar
    Aug 2012
    steerers are a lot thicker than seat tubes
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    'brifter' is f'ing stupid
    Seat posts are usually aluminum as well.
    OP...is it threaded or not?
    #promechaniclife
    Apr 2011
    I thought I was the only one to use plumber's tube cutter for cutting carbon fiber tube. I've cut 2 carbon steerer tubes with it last few years. Works fine.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    You can take apart the steer tube guide and use thinner spacers in order to make it (effectively) an sg6. I just did this in reverse.
    Mar 2012
    Quote Originally Posted by rideit View Post
    Thanks. I think I'm gonna try this
    Never Give Up!
    Mar 2009
    I have used my plumber's tube cutter to cut down my Aluminum Steer tube with no issues
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
  1. Replies: 9
    Last Post: 08-21-2014, 01:01 PM
  2. Blade type for steerer cutting?
    By Jdub in forum Components, Wrenching
    Last Post: 04-22-2005, 02:09 PM
  3. cutting steerer tube
    By argylesocks in forum Bikes, Frames and Forks
    Last Post: 01-18-2005, 12:13 PM
  4. Cutting a threaded fork steerer
    By B2 in forum Components, Wrenching
    Last Post: 01-02-2005, 02:29 PM
  5. Cutting a steerer too short
    By hrv in forum Components, Wrenching
    Last Post: 12-05-2004, 11:56 AM
