Cutting steerer tube. Frayed a bit at the end
Results 1 to 7 of 7
    Mar 2012
    Was cutting the steerer tube and right at the end of the cut it frayed a bit. I never turned it and cut straight through.
    Is that okay? I flied the top of it. The pic looks kinda worse then it is
    Reputation: nova_rider's Avatar
    Sep 2005
    You should be fine.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Put a little clear nail polish in it. When it dries, it will seal the ends.
    Sent from my SM-G930V using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Reputation: Akirasho's Avatar
    Quote Originally Posted by frdfandc View Post
    .. or a "slow" curing gap filling super glue you can get from hobby or hardware.
    Obviously, you'd apply only to affected area before assembly... "slow" cures can be around 2-5 minutes... check instructions.
    'brifter' is a lame word.
    Sand it down a bit and carry on. Happens all the time.
    I work for some bike racers
    and a bunch of skateboards
    Jun 2005
    I 2nd definitely sand it, and yes nail polish sounds like a good bonding agent. BTW next time use proper tools if you didn't.
    Minimal 24 Teeth hacksaw blade, use a steerer cutting guide like from Park.
    Not worth messing up a $300 fork with cheap tools.
    Quote Originally Posted by oberwil View Post
    If you're going to advise using the proper tools I'd go with a carbon specific carbide blade instead of a hacksaw.
  1. Replies: 9
    Last Post: 08-21-2014, 01:01 PM
  2. Cutting Carbon Steerer Tube
    By Dunc in forum Components, Wrenching
    Last Post: 10-15-2007, 08:31 AM
  3. Question about cutting a threaded steerer tube...
    By bismo37 in forum Bikes, Frames and Forks
    Last Post: 02-19-2007, 07:52 AM
  4. Question about cutting carbon fiber fork steerer tube
    By velonomad in forum Components, Wrenching
    Last Post: 04-27-2006, 11:12 AM
  5. cutting steerer tube
    By argylesocks in forum Bikes, Frames and Forks
    Last Post: 01-18-2005, 12:13 PM
