CX's examples of how not to take care of your bike... - Page 12
Page 12 of 13 FirstFirst ... 10111213 LastLast
Results 276 to 300 of 312
  1. #276
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    If anyone wants to see some messed up bikes. Join "The Funny Side to Bike Mechanics" on Facebook. There are some doozies being posted daily.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
  2. #277
    Slowski
    Reputation: eboos's Avatar
    Mar 2011
    Quote Originally Posted by 202cycle View Post
    Time for a tune up. This guy called me yesterday to ask how much a tune up would cost. When I gave him the price, he freaked out. "My car mechanic charges less than that. My plumber..." Like somehow my trade is worth less than theirs. Believe me, his car mechanic or plumber would have charged extra for this sh#t.
    The guy must have been a beast to spend so much time in the small cog to wear it out like that. Or the rear mech was so crudded up the bike hadn't shifted in years.
  3. #278
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by eboos View Post
    I actually knew someone whose derailleur pulleys looked like that.
  4. #279
    Sep 2011
    This did not work.
  5. #280
    Reputation: velodog's Avatar
    Sep 2007
    This did not work.
    Is that some kind of an attempt at a weld of some sort?
    Too old to ride plastic
  6. #281
    Reputation: Akirasho's Avatar
    Looks as if someone thought aluminum welded just like steel...
  7. #282
    Nov 2010
    This did not work.
    It looks like someone knew where the equipment was, and how to turn it on.
    After that, the knowledge curve quickly flattened.
    My dad once welded a pedal to my crank, (back when we actually used steel cranks).
    I am not sure what happened here.
    Sent from my XT1635-01 using Tapatalk
  8. #283
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    I was thinking...
    ... laid bike down on its drive side in a seemingly dormant lava field near Kīlauea... to get the cool selfie, which is a requirement when you venture to any exotic location.
    Complications ensued.
  9. #284
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Quote Originally Posted by bvber View Post
    ^ There are spas with a pool of little fishes that eat / clean dead skin off of your feet when you dip in. I wonder if there is a version of such creatures for gunked up machine parts... Attachment 325105
    Yes, it’s called an ultrasonic cleaner.
  10. #285
    Russian Troll Farmer
    Sep 2016
    This did not work.
    Well, it COULD still 'work' as a cudgel.......
    "L'enfer, c'est les autres"
  11. #286
    This did not work.
    … the more I look at this, the more I'm convinced that someone left their torch within hand's reach of their 5 year old.
  12. #287
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    If you ever seen inside a manure spreader.... that's what it looks like. Maybe the rider suffers from IBS.
  13. #288
    May 2011
    It is correct on your bike. The screw that is sticking out is the one that adjusts cable tension by moving the link. It's specifically noted in the instructions and on the video. The new derailleurs are definitely a little more work to set up but the performance is good enough that it's worth it. The trick is to do them on a regular basis...which is hard if not impossible for the normal guy that doesn't work in a shop. I had to watch the video the first 8-10 times I had to set them up.
    Absolutely agree and WAY better than those damn in-line cable adjusters that were needed with the previous gen.
    Interesting/amusing FD story... I recently purchased a high-end, lightly-used demo bike. I had to swap the cranks from my previous "A" bike which, being 52/36 vs. 50/34 on the demo, required resetting the FD. Couldn't figure out why I couldn't get the 9100 FD support screw in far enough to touch the braze-on. Backed it out and discovered that whichever newb shop mechanic built the bike had put blue Loctite on the support screw! What exactly is the thinking *there*???? Same genius had put Loctite on the BB threads! I mean, yeah, it was Italian thread but is it really that hard to just torque it properly and keep an eye on it????
    Well, you know, that's just, like, your opinion man. - The Dude
  14. #289
    Dec 2005
    Quote Originally Posted by Akirasho View Post
    I bet that the mission was a total success, and all they were trying to do was to salvage the pedal.
  15. #290
    'brifter' is a lame word.
    Fear not, I've been slacking on this thread but I'm back. Guy brings in a bike today, says he thinks he may have screwed up the front brake.
    Possibly...
    Rotor is definitely toast...
    Eh, pretty sure I've seen worse...
    But not worse than this...and what's left of it is not flat. The piston actually bent the backing plate a bunch.
    The brake was actually using the piston on that side as the friction material so I have to do a rebuild w/ new pistons/seals.
    I work for some bike racers
    and a bunch of skateboards
  16. #291
    Oct 2017
    ...I have to do a rebuild w/ new pistons/seals..
    You're a better man than me. If I were that persons mechanic, they would be buying a new caliper, rotor, brake hose/fittings, etc..
  17. #292
    Quote Originally Posted by Finx View Post
    New rotor for sure. The hose and fittings are fine.
  18. #293
    [REDACTED]
    May 2014
    How was he even able to brake? Fred Flintstone??
  19. #294
    After the pad wore through it was piston v rotor.
  20. #295
    He's pretty sure the noise is coming from his cassette. I'm pretty sure it's not. All that rust came from the 2 bearings, the bolts and bushing are aluminum.
  21. #296
    [REDACTED]
    May 2014
    Interesting approach.........but eventually fatal.
  22. #297
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    What bike frame if you don't mind? That almost looks like a seat-tube/stay junction...which would mean that bearing had the weather seals of tissue paper to be that bad.
  23. #298
    Older Trek Domane. The bearing seals aren't the issue. It's sweat/water getting under the Iso Speed cover (the part I'm holding in the first photo) and never doing any maintenance.
  24. #299
    tlg
    tlg is offline
    May 2011
    Seals only protect the innards of the bearing. There's lots of exposed steel which will 'bleed' rust when exposed to rain and sweat.
  25. #300
    Feb 2013
    What maintenance is required on the Domane Iso Speed? Should it be taken apart occasionally?
  1. Is it a scam? check here for typical examples.
    By Coolhand in forum Classifieds Feedback - Scam Warnings
    Last Post: 07-16-2018, 08:43 AM
  2. 10 examples of brilliant shadow art
    By Henry Porter in forum The Lounge
    Last Post: 01-25-2011, 08:05 PM
  3. Replies: 126
    Last Post: 05-07-2009, 11:50 AM
  4. Some examples of short-reach handlebars?
    By dawgcatching in forum General Cycling Discussion
    Last Post: 07-23-2004, 12:15 PM
