CX's examples of how not to take care of your bike... - Page 7
Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 151 to 175 of 226
  1. #151
    Oct 2002
    Quote Originally Posted by TJay74 View Post
    I work on some friends bikes. Doesnt matter how many times I try ...............................the bike always returns with the same bad habits in place.
    start charging real rates not mates rates, and charge them for cleaning time. That might get them the message.
  2. #152
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    I work on some friends bike on the side as a shade tree mechanic and my OCD goes crazy every time I deal with their bikes. Doesnt matter how many times I try to drill things into their heads the bike always returns with the same bad habits in place.
    I think I would get "really busy" very quickly.
  3. #153
    [REDACTED]
    May 2014
    Wow CX, it's been over a month since you posted an example here. I guess the rainy season is there in NoCal now and people aren't bringing bikes in much?
  4. #154
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Or, after being stuck not riding because of the forest fire smoke, as soon as the air was clear but it started pouring everybody rode in the rain and he's been stuck cleaning and fixing CX and gravel bikes for the last month...
  5. #155
    'brifter' is a lame word.
    A variety of things, but now that it's slowing down a bit, here's something. Don't drag your brakes down big hills w/ carbon clinchers. Still a thing I guess.
    This is the normal width of the rear rim in the middle of the brake track...
    And this is how far it blew out...
    Don't drag your brakes folks. Especially the rear, it doesn't really slow you down at all and just wrecks ****.
    I work for some bike racers
    and a bunch of skateboards
  6. #156
    Oct 2013
    My last MonsterCross ride I stopped 1/2 the way through to tighten my front disks up (mech), and the pads were GONE! That DA mechanic! ....me!
    BANNED
  7. #157
    [REDACTED]
    May 2014
    1) I don't drag my brakes.
    2) I don't use carbon rims.
    Win-win!
  8. #158
    Reputation: Fredrico's Avatar
    Jun 2002
    Win-win!
    Race tires, carbon rims! Disc brakes! Stop that bike on a dime! Whoops!
  9. #159
    gazing from the shadows
    Jan 2003
    Since I don't have a tandem with a drag brake, I don't.
    Some people consider what controls do (shift and brake), some consider HOW they do them (friction, forcing a chain into metal from the side). I'm guessing your customer will move from the first group to the second, at least for brakes.
  10. #160
    Quote Originally Posted by DaveG View Post
    Why do people want to convert others to their chain lube regiment? Its like chain lube Jehovah Witnesses.
    Quote Originally Posted by SPlKE View Post
    Exactly. That's why I keep telling people... forget the homebrew, forget all those fancy new chain lubes. Get ProLink, the one and only Best Chain Lube. ProLink... It's got what chains crave.
    Quote Originally Posted by QuiQuaeQuod View Post
    Exactly!
  11. #161
    Here's one for you mountain bike guys w/ old Reverbs. Don't strap your saddle bag to the upper part of the post then wonder why it won't work anymore.
  12. #162
    [REDACTED]
    May 2014
    I didn't get this one at first. Then I realized it's a dropper seatpost.
  13. #163
    If you have $pendy carbon parts I implore you to get and use a torque wrench. Pretty much always gonna be less expensive than ruining a $600.00 carbon bar/stem.
  14. #164
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    That would have been a bad crash had that bar failed.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
  15. #165
    Oct 2013
    Man'splain to me how a torque wrench would not cause a failure in that handbar bend?
    BANNED
  16. #166
    This was on a brand new bike out of the box. Trek's new boxes nearly eliminate shipping damage of the normal type. Obviously if you run over the box w/ a forklift the bike is toast, but normal dropping/banging around won't do much to a bike if it's in one of these, and there was no damage to the outside of the box. That leaves over-tightening the clamp. In this case the levers were low on the drops but over-tightened is over-tightened.
  17. #167
    [REDACTED]
    May 2014
    Maybe he was watching one of those You Tube videos where some hamfisted mechanic was leaning on bolts so hard, the bike stand would almost fall.
  18. #168
    It's no secret that I'm a SRAM guy. Since the very beginning of their road line I've worked on it and used it personally. But...for the last couple years their crank bolts have a nasty habit of galling in the aluminum 29 and 30mm axles making it super hard to remove them. Just had one in a new Trek Top Fuel 9.9 w/ XX1 Dub cranks so stuck out of the box that this happened...
  19. #169
    Oct 2013
    Yea, and were u using your torque wrench? hu uh?
    Put some anti oxidation compound on those bolts when you put them back on.
    BANNED
  20. #170
    That was tring to get the crank OFF, and I didn't install it. Prep: Use caution tape when performing dangerous jobs.
    Always use new, sharp tools.
    Progress...
    And done.
  21. #171
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Jeebus. You had to destroy a crank...right out of the box?? WTF? This is your second Trek boxing flaw in what--a month?
  22. #172
    Yeah, but this is more SRAM's problem than Trek's. I spoke to one of their CS reps earlier and they know about the problem. They've come up w/ a new bolt or maybe they're just putting anti-seize on them instead of thread locker. I'm fairly sure that Trek's builders are using torque wrenches, I've seen them build bikes. I've had many problems in the past w/ the alloy bolts galling in alloy axles so it's nothing new. SRAM will replace the crank so it's not a big deal. I'll buy a stronger 8mm bit.
  23. #173
    [REDACTED]
    May 2014
    I'm a bit confused, but why would using anti-seize be a problem?
  24. #174
    Reputation: velodog's Avatar
    Sep 2007
    I think that he's saying that they may be using anti-seize instead of thread locker now.
    Too old to ride plastic
  25. #175
    ^This^ They have been using thread locker and have switched to some typed of anti-seize coating. We'll see how it works.
  1. Is it a scam? check here for typical examples.
    By Coolhand in forum Classifieds Feedback - Scam Warnings
    Last Post: 07-16-2018, 08:43 AM
  2. 10 examples of brilliant shadow art
    By Henry Porter in forum The Lounge
    Last Post: 01-25-2011, 08:05 PM
  3. Replies: 126
    Last Post: 05-07-2009, 11:50 AM
  4. Some examples of short-reach handlebars?
    By dawgcatching in forum General Cycling Discussion
    Last Post: 07-23-2004, 12:15 PM
