DA 7900/9000 crank arm pinch bolts
Results 1 to 4 of 4
    Feb 2005
    Is there an alternative to use? The seem to be soft and easily rounded out. Yes, that means I spent an hour yesterday drilling one out.
    'brifter' is a lame word.
    Make sure your wrench is in good shape and fully engaged in the head of the bolt. I'm not aware of any easily acquired bolt that has a head small enough to fit. Just be careful. You can easily order replacements.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2005
    Thanks. I got in a hurry and the wrench slipped when switching my power meter arm to another bike. I had replacements ready to go and usually replace the bolts after a couple of installs to avoid the problem.
    Jul 2018
    You can replace them with the Tiagra/105 bolts, which are *slightly* better.
  1. Is DA 9100 Left Crank Arm Compatible with 7900 Cranks?
    By Drone 5200 in forum Components, Wrenching
    Last Post: 12-07-2017, 02:56 PM
  2. Dura Ace WH-9000-C24-TU vs WH-9000-C24-TL
    By Philhumphrey in forum Wheels and Tires
    Last Post: 02-22-2014, 12:50 PM
  3. Stages DA9000 or 7900 crank arm.......?
    By barters in forum Components, Wrenching
    Last Post: 11-05-2013, 11:56 AM
  4. anodized bolts/Ti bolts... bolts in general...
    By Cruzer2424 in forum Components, Wrenching
    Last Post: 02-16-2007, 06:56 AM
  5. FSA crank arm bolts
    By jp_nyc in forum Components, Wrenching
    Last Post: 04-17-2006, 01:18 PM
