Results 1 to 5 of 5
    Cooper1960
    Oct 2010
    Derailleur handle larger gear?
    I have a 2008 Campy Chorus ten speed, the rear cassette has a 28T large cog and I am wondering if I can go up to a 30T or maybe even a 32T.
    How can I tell if I can go to a bigger gear with my current derailleur?
    Miles of agony for moments of ahhh!
    'brifter' is a lame word.
    Quote Originally Posted by Cooper1960 View Post
    Google is an amazing thing. That said it will work w/ up to a 29 tooth cog. Since the rear derailleur has to have the capacity to do 2 things: shift to a certain size big cog, AND wrap the chain needed to go big/big. You might get the derailleur to shift to a bigger cog than 29 but it won't wrap the chain needed, so depending on how you size your chain you're likely to rip the rear derailleur off the bike if you shift into big/big/.
    I work for some bike racers
    and a bunch of skateboards
    Cooper1960
    Oct 2010
    Thank you
    Feb 2002
    Or size the chain so it droops in the small small and "don't go there" which you shouldn't do anyway.
    Reputation: smokva's Avatar
    Jul 2004
    I could get my Campagnolo Record 2009 11sp double rear derailleurs up to 32T.
    Also, new Veloce 10 sp derailleur works up to 32T.
    Derailleur will not be limiting issue, length of your hanger will. If your hanger is not long enough you can find hanger extension on eBay for few bucks...it will solve all your problems.
    Don't be afraid about cage length, short cage is enough for 53-39 cranks to work with 12-32 cassette perfectly on road bike.
    I have large 61cm frame, with smaller frames and shorter chainstays you might have to (probably not) leave your chain a bit longer so that 39/11 or 12 (first cog) won't be usable, but you shouldn't be there anyway.
    Sent from my SM-G925F using Tapatalk
    Ante Smokrovic
    2009 De Rosa Neo Pro - Fedaia, Giau, Pordoi, Sella, Gardena, Campalongo, Falzarego, Valparola, San Pellegrino, Valles, Staulanza, Vršič, Mangart, Furcia...
    2003 De Rosa Team - Stelvio, Gavia, Mortirolo, Bonette, Agnel, Izoard, Fedaia, Giau, Pordoi, San Pellegrino, Staulanza, Manghen, Vršič, Učka, Mangart, Biokovo, Eisentalhöhe, Schonfeld, Schiestelscharte, Flattnitz...
  1. 10 speed what derailleur for larger cassette
    By RoadCube in forum Components, Wrenching
    Last Post: 03-20-2018, 08:13 PM
  2. Can I go to a larger gear in the cassette?
    By Brone in forum Components, Wrenching
    Last Post: 10-26-2010, 11:05 PM
  3. Flat Handle Bars or Curved Road Bike Handle Bars
    By EntropyAJB in forum Commuting, Touring and Ride Reports
    Last Post: 05-14-2004, 07:22 AM
  4. riding a frame slightly larger than recomended - long
    By fraDcat in forum General Cycling Discussion
    Last Post: 04-08-2004, 07:12 AM
  5. Larger than 27 Rear cassettes for 9sp
    By bwong88 in forum Components, Wrenching
    Last Post: 03-08-2004, 06:51 AM
