derailleur hanger alignment Gauges... are they worth the investment?
Results 1 to 25 of 37
    Never Give Up!
    Mar 2009
    Looking to see if anybody has any advise/input on rear derailleur hanger alignment gauges?
    I'm thinking of purchasing one to include in DIY workshop bag of tools but I don't know if there is a real big difference with one from another. they all appear to function in the same manner, so my concern is the reliability and ease of use, which they seem pretty simple to use!
    I'm looking at the following:
    https://www.amazon.com/dp/B0784P9BGM...ogi&th=1&psc=1
    https://www.amazon.com/dp/B010T6L22E...ogi&th=1&psc=1
    https://smile.amazon.com/dp/B077SZBZ...t-best-20&th=1
    Are they worth owning vs going to LBS and/or do you have other suggestions/brands other than one ones I noted above?
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
    Reputation: velodog's Avatar
    Sep 2007
    I've got one and think that it's a good tool to own. Any time the derailleur is off the bike I check. If my shifting action changes I check. When I re-cable, I check. If the bike gets a hard bump or falls on the drive side, I can check. What does it take before you bring the bike to the shop to have the hanger alignment checked? I've had to tweak hangers on my bikes enough times to think that it was money well spent.
    How much of your bikes maintenance do you do, and are you willing to tweak the hanger if it needs it?
    Too old to ride plastic
    Sep 2009
    I think it's definitely worth having. I check the alignment everytime I do a full cleaning or if the shifting seems off. Most times there is some misalignment.
    My road bike has Di2 and it's very forgiving of misalignment so I don't notice much improvement with it but my gravel bike has SRAM Apex and the difference there is very noticeable.
    I made my own tool using a length of 3/4" x 3/4" square steel tube. I drilled a hole in one end and found a bolt to match the hanger threads. I just use some washers to space it out far enough to clear the frame and a tape measure to measure the gap between the end of the tube and the rim. I'm sure the professional ones would be easier to use but I'm too much of a tightwad to spend the cash.
    'brifter' is f'ing stupid
    Is it worth having/using? Absolutely! It's one of the most used tools I have. EVERY new bike gets checked, every bike I double check for another mechanic gets checked, and I would guess it gets used on 50-70% of the tune ups I do. All 3 of the ones you linked to are probably garbage...the Park and the other one that looks like the Park are definitely crap. The green HAG in my box from https://www.abbeybiketools.com/products/hag is hands down the best one made. Worth every one of the considerable number of pennies you'll pay for it. Easily my favorite tool.
    #promechaniclife
    What the what???
    Jul 2009
    Quote Originally Posted by J.R. View Post
    I have one like that in my garage, too. Nice!
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    Apr 2006
    +10000
    Sent from my SM-G973W using Tapatalk
    Never Give Up!
    Mar 2009
    I'm doing more and more of my own maintenance, haven't been to the LBS in about year or so, except to pick-up a few parts/accessories here and there... at this time, it would take something catastrophic to take my bike the local LBS!
    I know we have are favorite tools and believe me theirs nothing wrong with that as I asking for input and I respect your opinion(s), but what's make the three examples I posted garbage?
    And since I don't do this for a living and if one was not okay with spending $200 on tool. What other(s) would you recommend (you must of had a favorite before you found the HAG)
    2007 IRONHORSE HT
    Nov 2002
    I've got a Park DAG-1. It works well, but I have to keep tightening a set screw that takes the play out of the pivot and it doesn't fit one of my bikes. Park has corrected the second issue with a newer version.
    Quote Originally Posted by ROAD&DIRT View Post
    I know we have our favorite tools and believe me there's nothing wrong with that as I asking for input and I respect your opinion(s), but what's make the three examples I posted garbage?
    And since I don't do this for a living and if one was not okay with spending $200 on tool. What other(s) would you recommend (you must have had a favorite before you found the HAG)
    ftfy.
    The Park and anything built like the Park are not precise, and they aren't durable. They use a silly little o-ring to hold the feeler. If you use one as much as I do they're crap. If you're dealing w/ modern 10-11-12 speed drivetrains they're crap. I never had a favorite one prior to getting the HAG cuz they all sucked.
    The Unior tool is actually really nice and works w/ smaller than 26" wheels, and it's less expensive.
    https://uniorusa.com/store/hanger-genie-1602-5/
    #promechaniclife
    Nov 2009
    Hyperbole.
    Sent from my Moto G (5) Plus using Tapatalk
    Reputation: Srode's Avatar
    Aug 2012
    Yes they are worth if you plan to do most of the work on your own bike.
    ftfy.
    I don't work on bikes for a living like you do but I sure don't see anything wrong with the park tool. Sure, the o-rings are a little fiddly, and perhaps not as precise but realistically I don't see how it would wear out or why some high degree of precision is needed. I mean, how closely aligned do you really need to get the DR for great shifting? Getting it within a few mm measured at the rim (about 1/2 a degree off perfect alignment) in the horizontal or vertical position is sufficient right? The O-rings if someone uses them carefully will measure closer than that.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I would agree that Park tools leave something to be desired, but unless you are an LBS mechanic, the Park version is adequate enough. You get what you pay for.
    When do I check my alignment? Only if I suspect a problem - shifting is funky and it's not due to another known problem. If it aint broken.............
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Never Give Up!
    Mar 2009
    What the heck, one of the derailleur tools I was originally viewing/considering from Amazon last week...
    "BIKEHAND Bike Bicycle Frame Rear Dropout Derailleur Hanger Alignment Gauge Tool"
    has jumped up in pricing ($67.00 to $88.99) and is now only available from a direct ship company in Australian. Is there really that big of a demand for these tools?
    2007 IRONHORSE HT
    Banned Sock Puppet
    May 2014
    Honestly, I wouldn't order anything from overseas until the plague is over - unless you don't mind waiting a few months for it.
    "With
    -- DCGriz, RBR.
    Never Give Up!
    Mar 2009
    ^^^ This.... agreed, I'm not holding my breath and/or plan it!
    2007 IRONHORSE HT
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    I have an order coming from UK. 5 day shipping.
    Reputation: OldZaskar's Avatar
    Jul 2009
    Alright CX, I usually agree with you... but I have to push back, or at least ask why. Why is the ParkTool 2.2 garbage?
    My ParkTool derailleur tool gets used a couple times/yr. And that includes lending it out. It has worked well when I needed it. I totally get why YOU would want - and be willing to spend big $$$ for - the best tool on the market.
    Is this like my buddy who's a contractor knocking my Ryobi tools? ;-)
    Banned Sock Puppet
    May 2014
    Let me know when you actually get it.
    "With
    -- DCGriz, RBR.
    Oct 2017
    My DAG is by far my most beloved tool. I discovered it after having trouble getting RD indexed properly. Once I got the hangar aligned, the bike was perfect. I have since taken up the habit of checking the hangar frequently. It's easy and quick to do, and since it's so easy to ding a derailleur, it's definitely worth doing.
    And i do own the Park version. It could be better (the o-rings are a bit fiddly), but it works fine, and is very durable, getting knocked around in the bottom of my toolbox (I really need to get my setup organized like CX has his - that looks amazing).
    Quote Originally Posted by OldZaskar View Post
    If you're really careful the Park will work fairly well...for a while. It's the size/weight/quality of manufacture that is lacking w/ most Park tools. It's also not possible (in theory) to get past the seatstay w/ the Park. It's easy w/ the HAG. Once you use an Abbey HAG (or the Unior) you'll agree.
    #promechaniclife
    Apparently a lot depends on luck and maybe type of hanger.
    I've only been riding 10 years but ride a ton of miles and not once have I had a need for one.
    I did have a frame with a replaceable alloy hanger but maybe having steel and Ti non replaceable ones for a ton of miles has something to do with never having a need for the tool.
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    This has been my experience as well. I have had a Shimano derailleur gauge that I was given, and I think I've used it once. Others' MMV, obviously.
    I'm not that hard on my bikes, so that may have helped.
    Donald Trump has never had a wife he didn't cheat on.
    "Oh my god. This is terrible. This is the end of my presidency. Im fd.
    Frog Whisperer
    May 2003
    I have 1 (Park, btw and it does not have an o ring anywhere) I use it periodically. As a result of me having one, none of my friends need their own.
    Of course I'm sure...that doesn't mean I'm right.....
    "There's no sense being stupid unless you show it."
    Never Give Up!
    Mar 2009
    So I decided to pull the trigger and purchase the "CycloSpirit Derailleur Hanger Alignment Gauge" it should be here Wednesday.
    I will follow-up once I receive and use it... as a result of this weekends riding, I noticed my shifting is a little wonky at the moment. The derailleur is smooth when shifting from the 11th cog through the 14th, and starts to get a little clicking sound from 15, 17, 19 & 21. then 23, 25 & 28 appear to be fine, not sure if this a result of bent derailleur or not
    CX; I like your setup and appreciate your input, but I can't justify the spend.
    2007 IRONHORSE HT
    Oct 2017
    Quote Originally Posted by Touch0Gray View Post
    the o-rings go on either side of the small indexing arm that extends out to index the rim at various location. The o-ring is used to mark (index) the small arm so when you pull it back to pass the seat stay and chain stay, you can measure that index against other points on the rim.
    How are you marking/indexing yours if not with an o-ring?
    I don't mind the o-ring. It's not the most precise way of doing things like this, but it's well within the tolerances of what we are measuring. I believe +/- 2mm is the spec for it. I can easily tweak to within 1mm using this tool.
    The thing I like the least about them is when they 'disappear' (presumably off to hang out with my missing socks) after being in my tool drawer for some period of time..
  1. RD Hanger Out of Alignment
    By GKSki in forum Components, Wrenching
    Last Post: 08-14-2018, 08:01 PM
  2. Replies: 5
    Last Post: 04-18-2013, 07:16 PM
  3. Derailleur hanger alignment, for CheapSkates
    By CheapSkate in forum Components, Wrenching
    Last Post: 09-10-2012, 09:23 AM
  4. derailleur hanger alignment
    By PoorCyclist in forum Components, Wrenching
    Last Post: 01-13-2012, 03:08 PM
  5. hanger alignment
    By Touch0Gray in forum Components, Wrenching
    Last Post: 09-01-2009, 01:48 PM
