Derailleur Question: Replace RD-6870-SS with RD-8050-GS?
Results 1 to 3 of 3
    Apr 2008
    I'm getting older with injuries and want to put on the Shimano 11-34 cassette, CS-HG800. I have the 2014 Ultegra Di2, short cage. I know my RD-6870-SS will not work so I'm thinking of getting a RD-8050-GS. I know that will require a firmware update.
    Questions:
    1. Will the direct mount be a problem or does the bracket already on the RD-8050 fit my current derailleur hanger?
    2. Will my current electric cable just plug into the RD-8050?
    3. Will my junction box, SM-EW67A, be compatible with the RD-8050 with the firmware update?
    4. If not, and I can find a new RD-6870-GS, can I just replace the derailleur without the firmware update? I know to adjust the B-Screw, etc.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    #1 Fit will not be an issue. Use the included and pre-installed B-Link
    #2 All your parts are e-tube. Yes. Plug and play. Use an e-tube connector tool for unplug and re-plug.
    #3 Per the latest Shimano compatibility chart, if you are using the BTR2/BMR2 then yes: https://e-tubeproject.shimano.com/pd....4.3-00-EN.pdf
    #4 You would probably need to do a firmware update anyway. Di2 parts have an astounding variance in what firmware they ship with even from the same retailer.
    Reputation: Srode's Avatar
    Aug 2012
    Works fine, I did the same to use a bigger cassette but in my case an 11/36, I was able to use 11/34 with the 6870 long cage.
    If you have the new battery (BT-DN110) you will have 'Gear Control' with the new set up, and in fact might have it with the older battery too, I haven't tried it. Gear control prevents cross chaining small small to the first 2 cogs on your cassette which helps keep you out of slack chain situations.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
  1. 8050 rear mech with 6870?
    By bing181 in forum Components, Wrenching
    Last Post: 07-23-2019, 05:30 AM
  2. Replacing RD9070 derailleur with RD 8050
    By sasquatch16 in forum Components, Wrenching
    Last Post: 06-14-2019, 04:45 PM
  3. New RD (6870 or 8050) with 6870 groupset?
    By RoiH in forum Components, Wrenching
    Last Post: 04-26-2018, 01:30 PM
  4. 8050 vs GS
    By wvmtb in forum Shimano
    Last Post: 10-14-2017, 01:33 PM
  5. Shimano Ultegra RD-6870-SS rear derailleur compatible with 11-28 cassette
    By enduro_phreak in forum Components, Wrenching
    Last Post: 10-05-2014, 08:51 PM
