Di2 Bar End Shifters not working
Results 1 to 4 of 4
    Reputation: Srode's Avatar
    Aug 2012
    I added 9160 Bar end shifters to my 5 port A Junction box on a system with 785 disc brake levers, BTR2 Battery with 6870 front and rear DR. Nothing happens when I click either of the bar end shifts - thought this would be plug and play but apparently not. From the Shimano compatibility tables it looks like these should work - do I need to do some programming or firmware updates to get them working?
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Jan 2014
    I don't know for sure because I've never installed these, but my guess is the system either needs a firmware update, or at least needs to be refreshed in order to "look for" the presence of the bar-end shifters.
    In either case I think the clear next step is to launch e-tube and see what it tells you.
    I know whenever I launch e-tube it ASKS ME if I have the climbing shifters installed (as if it can't see that on its own, but needs to be told).
    'brifter' is a lame word.
    Ours always asks if the R and then L sprint shifter is installed.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2012
    Thanks, E-tube fixed it. The software recognized the 9160 shifters after the battery firmware was updated, no questions asked. Then I updated all the component firmware and it was good to go.
    It might not have asked about the sprint shifters or climbing shifter because the 785 brake levers don't have a port to use them with and/or they aren't compatible with the battery.
    Gravel Rocks
    Trek Domane
    Trek Crockett
  1. Replies: 5
    Last Post: 04-05-2013, 11:00 AM
  2. Any one get the new Ultegra DI2 bar end shifters installed?
    By jackmen in forum Components, Wrenching
    Last Post: 01-20-2013, 10:56 AM
  3. SRAM bar end end shifters on downtube?
    By e39540is in forum Components, Wrenching
    Last Post: 10-17-2010, 08:23 AM
  4. Can Bar End Shifters be used as Down Tube Shifters?
    By Drevil in forum Components, Wrenching
    Last Post: 05-01-2008, 09:12 AM
  5. STI Shifters or Bar End Shifters?
    By Cyclesafe in forum Components, Wrenching
    Last Post: 03-27-2006, 05:04 PM
