Di2 RX-805 wonít shift to bigger gears with clutch on
Results 1 to 4 of 4
    Reputation: multirider's Avatar
    Nov 2007
    My rear derailleur will only shift in the smallest 5 gears of the cassette with the clutch on. Shifts through all of them with the clutch off. What would cause that? Is the clutch putting too much tension on the derailleur so it wonít shift? Is there a clutch adjustment that would loosen it up just a little so it will shift through all the gears with the clutch on?
    Reputation: Grog McCog's Avatar
    Jan 2020
    @multirider
    There is a clutch adjustment in the form of a little set bolt that pinches the bit of metal that wraps around the clutch mechanism. Take it apart, pull it out and clean it and lube it very lightly with something like Chris King ring drive lube, and then re-adjust.
    This link is useful:
    https://www.singletracks.com/mtb-rep...illeur-clutch/
    BTW, if you have a front derailleur, you don't need a clutch (on). Its primary function is to prevent the chain coming off a single chainring due to the absence of a front derailleur chain guide. The reduction of slap on the chain-stay is a side-effect, but not its primary purpose.
    I'm grateful my Di2 setup is pre-clutch.
    Nov 2007
    Thanks! It looks a bit tricky, I have an important race this weekend and little opportunity to ride / verify functionality this week, so Iím going to wait until after the race to do this. But the step by step instructions look pretty thorough.
    Jan 2020
    Yeah, just turn it off for the race. Good luck.
    It is far less complicated than that description indicates. There is a good chance it will work fine after you clean it (I just washed it out with WD-40, let it dry, and lightly re-lubed it.)
  1. Ultegra rear derailleur - clutch vs non clutch?
    By FasterStronger in forum General Cycling Discussion
    Last Post: 01-16-2019, 10:31 AM
  2. Di2 won't shift to top gears sometimes
    By aabbas in forum Components, Wrenching
    Last Post: 01-13-2017, 05:21 AM
  3. Right Shift Lever won't shift (105)
    By hamsandwich in forum Components, Wrenching
    Last Post: 07-27-2012, 07:30 AM
  4. I won! I won! I won!
    By CyreneSong in forum The Lounge
    Last Post: 08-26-2011, 03:40 PM
  5. Optic Nerve RX Redhawk sunglasses with RX adapter
    By daniell in forum General Cycling Discussion
    Last Post: 06-03-2008, 05:38 AM
