Di2: synchro or semi-synchro. Why choose?
Results 1 to 6 of 6
    May 2011
    Why isn't this a good idea: with default Di2 shifter setup, full synchro operation on the right-hand shifter and semi-synchro operation on the left-hand shifter—at the same time? Presently, you can only have one or the other.
    Lots of people do not like synchro of any kind, and I totally get that. But, for those of us who do use it, wouldn't this be cool?
    I know this isn't possible at the moment. I think it would be a useful feature for Shimano to add, though.
    ‘Hybrid Synchro’, anyone?
    (Please, somebody come up with a better name than this.)
    (Edited for clarity.)
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    I use both Synchro modes....and I honestly don't understand what such a "hybrid" would do in actual shifting terms that is different from the present modes.
    May 2011
    Thanks, Marc. You helped me to realise that my original post did not clearly express the idea of having both modes active at the same time, rather than choosing one or the other I've updated the original posting.
    Sep 2011
    Imagine this scenario: you intentionally want stay in the big ring (even cross chaining it) on a short power climb because you know the crest is arriving and you want to be in the big ring getting ready to power down the the descent after the crest.
    Now if Di2 allows you to use both semi and full sync modes, then this could lead to this sequence of shifting:
    1. as you approach the top of the climb (but not at the top yet) and need to shift into lower gears, full-sync mode might shift you into the small ring and smaller cog
    2. then as you crest the climb, you will now have to manually shift into the big ring (semi-sync mode), but this shifting will momentarily disrupt your cadence and probably will take you out of your rhythm.
    I use semi-sync mode precisely because I want complete control of the front derailleur to avoid the above scenario.
    May 2011
    Totally agree. I would envisage this to be an additional mode, not a replacement for existing modes. For people who are happy with one or the other, nothing would change.
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    As a di2 newb, I found this article helpful.
    https://www.velonews.com/2017/05/bik...o-shift_437682
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
  1. Semi-Synchro and Synchro-Shift together?
    By kestrel242 in forum Components, Wrenching
    Last Post: 01-26-2018, 08:28 AM
  2. Synchro 8 DT upgrade to Ergopower 8
    By GKSki in forum Campagnolo
    Last Post: 09-14-2016, 12:10 PM
  3. Replies: 8
    Last Post: 05-13-2015, 08:15 AM
  4. Please help me choose...Focus Cayo Di2 or Fuji Altamira Di2
    By El Guapo in forum General Cycling Discussion
    Last Post: 01-04-2013, 02:05 PM
  5. Campagnolo Chorus Synchro II
    By mj3200 in forum Retro-Classic
    Last Post: 04-09-2009, 09:07 AM
