Results 1 to 16 of 16
    Reputation: ultimobici's Avatar
    Di2 Syncro Shift Problem
    Looking for a solution to a issue with Di2 setup.
    I have the following setup
    Dura Ace 9170 levers
    Dura Ace 9150 mechs
    WU-111 Bluetooth
    Sram 11-30 cassette
    Easton 46/36 chainrings
    I be tried setting up the chainrings & cassette on the app but I keep getting an error message regarding the gear stricture.
    Any ideas?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    E-Tube has goofy lockouts on how many multi-shifts etc based on gearing. Which would be my first suspect as to why it is erroring out. WHat happens if you select 50/34 or 53/39 for your crankset? Last I looked D/A didn't support 46/36...but that was a while ago.
    There's lots of gearing selection oddities in e-tube
    Jan 2014
    +1
    Jus lie to E-TUBE and tell it you have a standard double with a standard 11-28 cassette and then you should be able to be semi and full synchro going. You won’t be able to configure the full shift points but you can’t really do this even with standard gearing.
    Jun 2004
    +2,
    Di2 only allows you to set the system to use whatever components Shimano currenly sells. Thus something like a 30/46 can’t be used in the software.
    Note that even when selecting current Shimano components, it’ll lock out the 2 smallest cogs while in the small ring, unless you tell it 39/53 or some other crank. If you select a 34/50 it won’t shift to the 11 + 12.
    In real world, you can lie, and tell the software you are using a 11-28 and 39/53, bit then just install whatever you want. The setup software doesn’t know you are using a 36/46. It only matters if you BlueTooth connect the shifting system to a compatabile dipslay such as Garmin or Wahoo. Then the readout of which cog/ring you are in will be incorrect.
    Jan 2005
    Quote Originally Posted by Steve B. View Post
    +2,
    Note...Garmin and Wahoo will read the correct gear position, it is only the actual tooth readouts and ratios that are wrong
    Sep 2011
    +2,
    on Di2 9150/8050 series, if you have a 36/52 or smaller crankset and you shift into the small chainring up front, then the rear derailleur will not be able to take up the chain slack if you shift into the 2 smallest cogs in the back. That's why Di2 prevents you from shifting into the 2 smallest cogs if your small chainring is 36t or less. A 39t chainring will not be an issue. So yes while you can fool Etube into allowing you to shift into the 2 smallest cogs while on a <36t chainring, it does you no good to do so.
    Jun 2004
    What I meant to type.
    Does anyone know if you can edit the settings file from e-tube?
    Sep 2011
    Quote Originally Posted by ultimobici View Post
    I didn't see any way you could in etube
    Sorry, what I meant was editing a file downloaded from E-Tube.
    Sep 2011
    nope, didn't see a way to edit the downloaded file either. Etube will allow you to download the bike's shifting profile, so that you could upload it back to the bike later should you wish (eg, after you've changed the bike's shift profile to something else and wish to revert back to old profile, then you'd upload the saved old profile.)
    But etube doesn't allow you to edit the downloaded profile though. But you really don't need to edit any downloaded profile though. You just need to edit the current "Shift Mode" to something you wish and etube will transfer the new settings to the bike. I understand you're wanting to set Di2 to use the 36/46 crankset and it's not allowing you, right? Then just use something like 36/52 and 11-30 cassette. It'll be fine. You will not gain or lose any Di2 functionality, none whatsoever.
    Thanks. I feared as much.
    Functionally it is fine. However, the display on my Garmin drives me up the wall!
    Jan 2011
    I know this thread is a couple months old, but I just discovered quite accidentally that you can edit what the Garmin head unit displays despite what is set in the e-tube app. Just go into the sensor details of the Di2 sensor, tap Front Gears (or Rear Gears if you want) disable the Automatic setting, and you can put in whatever numbers you want. Now your Gear Ratio and Gear Combo numbers will be accurate. This will not affect the Synchro Shift though.
    Jan 2005
    Quote Originally Posted by Martyk22 View Post
    Does it actually stick past a ride/reboot, now? When I was on Garmin I found editing the gears settings wouldn't stick past a reboot.
    Jan 2011
    Yep, just tried it. Just make sure to disable the automatic setting.
    Jun 2004
    When I discovered this a year or so ago, the next connection via BT would have the Di2 system override the Garmin. I'll give it a try again.
  1. Syncro
    By mackgoo in forum Campagnolo
    Last Post: 10-26-2017, 05:24 PM
  2. Syncro II Left Shifter Problem
    By Camilo in forum Campagnolo
    Last Post: 04-10-2015, 08:30 AM
  3. Campagnolo Syncro pulley Question
    By onespeedbiker in forum Retro-Classic
    Last Post: 09-06-2010, 04:43 PM
  4. Campy Campa Campagnolo Syncro DT shifters
    By paredown in forum Retro-Classic
    Last Post: 09-03-2010, 05:05 PM
  5. Campy Syncro question.
    By robert_shawn in forum Components, Wrenching
    Last Post: 10-06-2005, 04:06 PM
