Direct drive trainer with 11 speed cassette on a 10 speed bike
Results 1 to 3 of 3
    Jun 2009
    I have the Elite Suito direct drive trainer on the way. It comes with an 11 speed cassette preinstalled. The problem is my bike has a 10 speed cassette.
    What are my options here? Do I need to replace the cassette on the trainer with a 10 speed? Can I put an 11 speed cassette on my bike to match the trainer?
    Thanks!
    Nov 2013
    10 and 11 speed cassettes are typically interchangeable with the addition of a spacer washer when using the 10 speed (see picture below). Your trainer will likely come with a spacer washer.
    You'll likely be able to put the 11 speed cassette on your bike, but of course you'll need 11 speed shift levers and rear derailleur (Not so sure you need the rear derailleur, but definitely the shift lever.)
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by supermatt9 View Post
    No it will not work. While you could mount the bike and it'll 'operate' it'll shift like crap, skip, and miss gears. The spacing on the cassettes are different.
    Your options are:
    (a) Take the 10sp cassette off your wheel and put it on the trainer.
    (b) Buy a new 10sp cassette for the trainer.
    Quote Originally Posted by PoorInRichfield View Post
    It's a direct drive trainer. He doesn't need to touch the bike.
    JSR
    JSR is offline
    Feb 2006
    Iím brand new to this, but Iím using a 9-speed bike on trainer with 11-speed cassette. I found a gear that seems smooth enough and change resistance rather than shift gears. So yes it can be done, but...
    Iím recovering from a broken leg. Resistance is low, sessions are short and simple. I figure that when my training advances to more complexity Iíll move the 9-speed cassette to the trainer if necessary.
  1. Your Good Bike on newer direct drive trainer
    By gabkr in forum General Cycling Discussion
    Last Post: 01-13-2019, 10:23 AM
  2. Replies: 9
    Last Post: 07-06-2018, 07:44 AM
  3. direct drive vs tire drive smart trainers
    By DaveG in forum General Cycling Discussion
    Last Post: 03-31-2017, 05:26 AM
  4. 105 cassette 10/11-25 to DA 7900 10/11-27,28?
    By trekbiking in forum Trek
    Last Post: 06-16-2009, 10:24 AM
  5. Ride Shimano 10-speed - do I need 10-speed cassette on trainer?
    By serpico7 in forum Components, Wrenching
    Last Post: 08-08-2006, 12:33 PM
