Disc brake 101 question - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
  1. #26
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Slight tangent, I have not been able to find any documentation or markings on TRP rotors for minimum thickness. Right now I have TR-25 centerlock rotors. Anybody know?
  2. #27
    'brifter' is a lame word.
    works on all rotors with a saw tooth outside edge, but not all have that - Campagnolo has at least a couple current rotors that do not, a micrometer is a better choice for those to get away from the outside edge or you have to use a feeler gauge and caliper to see what if anything you can slide between the caliper edge and the rotor away from the edge.
    I don't worry about Campy disc brakes as I have never seen one much less had to work on one.
    I work for some bike racers
    and a bunch of skateboards
  3. #28
    Oct 2005
    Calipers and micrometers?
    Like CX, I just replace my pads when they look like they're wearing close to the return springs. I just glance at my rotors every so often to make sure they're not all gouged/grooved from running worn pads too long.
    Jeebus, we're not talking aerospace here.
  4. #29
    Since every rotor/pad is nearly the same thickness when new I'd replace at 1.5/1.55mm.
  5. #30
    Russian Troll Farmer
    Sep 2016
    Quote Originally Posted by dir-t View Post
    Calipers and micrometers?...
    Well, maybe you don't work in aerospace, but I do........
    "L'enfer, c'est les autres"
  6. #31
    When new is 1.85mm and worn out is 1.55mm we're talking about a .3mm difference. Tell me another way to measure that accurately.
  7. #32
    Apr 2011
    Slightly off topic, what do you do to speed up the "break-in" of new disc brake pads? I know it take a bit of use to get the optimum friction from pads but does sanding them little bit help?
  8. #33
    No, it takes heat and repeated applications of the brakes to deposit some pad material on the rotor. 'Bedding in'.
  9. #34
    Oct 2005
    That's great but I rarely bring my work home with me and I certainly don't take it out on the trails.
  10. #35
    Oct 2005
    IMO, and what I must have misunderstood as your own, is that one can get a quick visual of pad wear and replace them before they start to foul up the rotors.
    Beyond that, when your brakes start to lose performance despite having good pads, you'll have a good indication that it's time for new rotors.
    In my experience, after 18 years of riding disc brakes, feel and intuition have always been an adequate substitute for accurate measurements.
  11. #36
    I think for guys like us working on our own bikes visual is good, especially for pads. When rotors get a lip worn on them, replace. For customers I need to provide numbers.
  12. #37
    Reputation: FeltF75rider's Avatar
    Feb 2012
    Been there done that. Also have a bit of machining experience. Donít think we need to carry it down to .0001Ē, A caliper is plenty accurate for a bicycle brake rotor.
  1. disc brake to caliper brake conversion?
    By cyclisme! in forum Components, Wrenching
    Last Post: 09-24-2015, 10:01 AM
  2. Brake pads Zipp 101
    By Srode in forum Components, Wrenching
    Last Post: 11-29-2012, 02:43 AM
  3. Replies: 8
    Last Post: 07-28-2010, 10:45 AM
  4. How to properly brake? (braking 101 questions)
    By afogel in forum Beginner's Corner
    Last Post: 07-05-2007, 08:51 PM
  5. Brake installation 101?
    By SpinWheelz in forum Components, Wrenching
    Last Post: 10-05-2005, 07:25 AM
