Disc brake problem - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
  1. #26
    Oct 2005
    After re-tightening the thru axle to a high degree, the rotor seems to be holding in the correct position.
    A related question: the rotor does seem to have a small amount of wobble between the sides of the caliper. When properly aligned, it is not enough to touch either brake pad, but it does get close. There is movement of perhaps 0.5mm. Is this within the normal range of rotor tolerances?
  2. #27
    Sep 2011
    Quote Originally Posted by rossb View Post
    take the bike out for a ride and report back.
    .5mm wobbling sounds "ok", but considering your issue, maybe you want a straighter rotor
  3. #28
    Oct 2005
    You're right, I think I might buy another rotor anyway. Unfortunately I've just come down with a bad cold so it will be a few days before I can take the bike out again.
  4. #29
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    You may be able to just swap front and rear rotors for experiment's sake, a lot of road bike rotors are the same diameter on both ends as opposed to mtn bikes. Apologies if you've done that already.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
  5. #30
    Reputation: Wetworks's Avatar
    Aug 2012
    Why not try straightening it out?
  6. #31
    Oct 2013
    I don't think your going to bend it closer than .5mm, that is pretty small.
    Unless you are really really good mech!
    BANNED
  7. #32
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    .5 mm is a very, very small amount of run out. I don't think you can get any better than that. You probably have .5 mm of run out in the hub brake mounting surface.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
  8. #33
    Reputation: nova_rider's Avatar
    Sep 2005
    The 0.5 mm value was reported by the OP. Was it measured or visual? If it was done visually, I suspect the runout is more than 1/2 mm.
  9. #34
    Oct 2005
    Quote Originally Posted by nova_rider View Post
    It was visual, so probably completely inaccurate.
    I've just ordered some SRAM Centerline rotors to try instead of the DA ones, so we will see if these are any straighter.
  10. #35
    Aug 2012
    DAs are excellent, have them on two of my bikes. Any bit of truing can be done by eye and feel after watching a few videos, just have a good truing fork on hand.
  11. #36
    Oct 2005
    Quote Originally Posted by Wetworks View Post
    Thanks, but the quickest way for me to turn these rotors into something with the shape of a small metal frisbee would be to go near them with a truing fork.
  12. #37
    Aug 2012
    Kudos for knowing your limits and admitting it. Hope it turns out well for you with the new rotors
  13. #38
    May 2011
    Huh, weird. Whenever I have a pad rubbing the rotor (AKA wheel), I just reach down and move the caliper a bit to the other side or open it up again. None of this piston press, bleeding, rotor truing needed. But then I have the only type of brake that greater than 90% of roadies ever need. I.e. rim brakes. Sure hope you guys have more fun futzing with your brakes than riding.
    Well, you know, that's just, like, your opinion man. - The Dude
  1. Disc brake fork on a rim brake frame
    By wradom in forum Bikes, Frames and Forks
    Last Post: 04-05-2018, 12:56 PM
  2. Disc Front Brake / Rim Caliper Rear Brake Experiment
    By mrwirey in forum General Cycling Discussion
    Last Post: 02-20-2016, 04:08 AM
  3. disc brake to caliper brake conversion?
    By cyclisme! in forum Components, Wrenching
    Last Post: 09-24-2015, 10:01 AM
  4. Shimano R785 disc brake problem
    By jamesgumby in forum Components, Wrenching
    Last Post: 09-20-2015, 03:41 AM
  5. Replies: 8
    Last Post: 07-28-2010, 10:45 AM
